Originally posted by Tom S. Not all rechargeable batteries are equal, nor are their chargers. Get a volt meter and check the output of one of your freshly charged batteries. I'm betting they aren't putting out sufficient voltage.
Voltage was showing up great on my batteries... After a bit of reading and a call to the store where I bought the camera, the problem should be the miliamps of the batteries wich is too low. Apparently Pentax recommends 2200 mah for the camera to fonction properly... My brand new batteries were 1100 mah. So the local camera store just robbed me a bit more with a brand new kit of Ansmann 2850 mah and charger for 79$ (wich I can get on ebay for 35$... but I needed it now so I had to pay way too much for it....
anyhow... I cant wait to play a bit with the camera after I charge the batteries and see in a month or so how they hold up....
The only concern I have is the fact that my lithium batteries used to do very well in cold weather, wich is not necessarily true of ni-mh batteries. Have any of you ever tried the Ansmann in cold weather (true canadian winter...between -10 or -20 celcius)?
