01-30-2011, 11:49 AM   #1
K-2000 won't turn on.
Help! I have not had my camera on in a month. When I turned it on..dead. Okay, replaced batteries ( copper top) and again turned it on. Dead. Yes, the batteries are all in correctly - first thing I checked as I have been known to put them in wrong before.
Now I am stumped...what am I missing?
Thanks much for any suggestions.
j
01-30-2011, 12:00 PM   #2
Ed n Georgia's Avatar
QuoteOriginally posted by neongirl Quote
j
Is the door for the SD card open?
and, you shoud use extended life lithiums batteries. Copper tops don't last long at all in digital cameras.
01-30-2011, 12:24 PM   #3
SD door is closed.
Ok..few min later I pulled the SD card ( 3rd time) and rearranged the batteries again( for the 6th time).. - and thanks, I will get some of the long life lithium next time i am out. Well, anyway, the camera turned on YAY! I have had trouble with it prior reseting to defaults on date, etc..and perhaps this is related to batteries or contact issues.
Thanks for your help, it was greatly appreciated.
j
01-30-2011, 12:37 PM   #4
It does absolutely Nothing? Or does it flicker on and then shut off?
01-30-2011, 12:40 PM   #5
wlachan's Avatar
Check all 4 old batteries with voltmeter and see if any one of them shorted & killed itself (along with the camera). Also, K2000 works best with NiMH or Lithium AA, not alkalines.
01-30-2011, 12:50 PM   #6
SD door is closed.
j
I've found myself cussing my camera because it wouldn't power up. Only to find that I still had the SD card door still open.
Energizer Lithium2 batteries work well and you might also want to investigate "Eneloop" Hybrid rechargeable NiMH batteries.
Glad your camera powered up and the data loss could be directly releated to the Alkaline batteries.
batteries, pentax help
To turn right or to turn left spura Pentax SLR Lens Discussion 14 04-15-2009 11:29 AM
K-m (2000) or the K200D beequick Pentax DSLR Discussion 15 12-03-2008 06:46 PM
Penat EL-2000 pentagor Pentax DSLR Discussion 7 06-10-2008 09:57 AM
My 2000 post!! vievetrick General Talk 11 01-24-2008 04:06 AM
2000 miles and 2000 pictures later Petthefish Post Your Photos! 4 10-03-2007 03:04 PM
All times are GMT -7. The time now is 01:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
