02-01-2011, 03:50 AM   #1
adwb's Avatar
IR remote advice please
I have had a quick look at previous posts via the search facility and not found the answer so I hope this is not a duplication.
Please can some one who has a remote for their K-x or the K-r tell me from what angles and what distance the receiver will "see" the signal, as I gather there is only a forward facing receiver?
[this relates to having the camera on a tripod some distance away from me to take wildlife photos close up rather than using a tele lens.]
Apart from the Pentax IR remote are there other more economical versions [cheaper] available that experience has shown to work?
I tried the television and dvd player remotes but they dont seem to trigger the camera
thanks
02-01-2011, 04:37 AM   #2
freddykrueger's Avatar
Well, tv remotes definitelly won't work
You can find pretty cheap IR remotes on eBay. I ordered one last thursday for $3, but you can find even cheaper ones there. I should receive it this or next week, so I can't tell you about the distance... Just search for "pentax ir remote"; or "k-x ir remote" for the original one (costs about $5).
02-01-2011, 04:41 AM   #3
piesforyou's Avatar
QuoteOriginally posted by freddykrueger Quote
Actually some people have reported the "off" button on some remotes to work!
I have a cheap one and the distance is fine, I havn't tried to max it out but it's definitely worked from ~3 metres away. The angles depend from which side. If the lens gets in between you and the sensor, the angle is quite restricted, but from the other side it's fairly good.
That's what I've found anyway.
02-01-2011, 04:57 AM   #4
The various IR remotes (including Pentax) have a maximum range of about 4m, and have quite a restricted angle of operation (maybe a 45 deg arc?) in front of the camera.
(No help I know, but other models have a rear facing IR window as well as a forward facing one.)
There are pleany of cheap IR remotes on eBay that work with Pentax dslrs. Maybe if you need more range you could modify one to work with a cable switch? Simple to make and cheap (less than 15 all in).
02-01-2011, 05:06 AM   #5
Hi, you can get a genuine Pentax remote pretty cheap on the market place here or on eBay. I bought mine for $8 a few years back and the price saving isn't enough to consider buying a chinese knockoff.
I can't give you exact angles but anything IR requires line of sight. If you can't see the IR sensor from where you are hiding you won't be able to trigger it. I've managed to use my IR remote with my bodies from around 12 - 15 metres away. The amount of ambient light could be an influence too.
If you want a cheaper alternative you can get a free application to use your PDA or iPhone as a remote. Of course, that's only cheaper if you already have the hardware.
Do the K-x and K-r have a remote socket? I made my own remote release and a 20 metre extension for a couple of $$ back when I had an *istD. You just need a couple 2.5mm stereo plugs and some phone wiring. I've still got the pattern somewhere - pm me if you want it.
02-01-2011, 05:20 AM   #6
QuoteOriginally posted by Dark_Mist Quote
That's impossible, today's PDAs don't have IR, nor does the iPhone.
And no, they don't have a remote socket.
Also, I don't think it matters if you buy original remote or "chinese one". They are both made in China and I would say that the "chinese one" has an advantage there because you can usually control even other-branded cameras with it.
02-01-2011, 06:58 AM   #7
adwb's Avatar
thanks every one just ordered a "cheap" one and will see what the range is.
02-01-2011, 03:10 PM   #8
ramseybuckeye's Avatar
I have a K20D and have a Pentax remote and a cheap ebay knockoff, the knockoff has a lot longer range. You'd have to test distance on your camera.
02-01-2011, 06:27 PM   #9
Ex Finn.'s Avatar
Well, yes they do, the problem is finding one that does transmit the correct code.
My Sony RM-PP505 remotes 2nd room button triggers K100D and K7 up to 30 feet away in daylight.
02-01-2011, 10:51 PM   #10
I just replaced the battery of my Chinese knock off remote, and remembered about this thread so I gave it a quick check . The remote triggered my K-20D at any angle even when the remote did not see the sensor of the camera or completely blocked by a corner of the walls . When I aimed at the side of the camera, the distance was about 4 meters, and when aimed 90 degree to the back sensor of the camera, the distance was about 10 meters ( I had no room to go any farther).
02-02-2011, 05:30 AM   #11
piesforyou's Avatar
It is possible - you have to purchase an IR 'dongle'.
A quick google throws up this one Infrared Transmitter | DSLR.BOT
QuoteOriginally posted by Ken T:
Do you think this worked because the IR was being reflected off the walls (sounds like you're testing indoors). Would be interesting to see how an outdoor situation compares.
02-02-2011, 09:36 AM   #12
QuoteOriginally posted by piesforyou Quote
Yes, I tested indoor and that's what I thought . It's windy today, when it calm down, I'll go out do an outdoor test to see how it does .
02-02-2011, 10:33 AM   #13
Which is three times more expensive than an original pentax remote
02-02-2011, 10:54 AM   #14
piesforyou's Avatar
Don't worry, I have come to the RESCUE! Anything with an audio jack can set off your camera! It costs 3 and supports anything your imagination can throw at it!
https://www.pentaxforums.com/forums/pentax-dslr-discussion/131633-absurdly-si...p3-player.html
02-02-2011, 11:34 AM   #15
Just1MoreDave's Avatar
QuoteOriginally posted by Ken T Quote
Just in case beginners are not aware, the K20D has two remote receivers, on the front and back of the camera. The K-x only has a receiver on the front, so it probably can't receive off-angle remotes as well. I think the extra IR receiver started with the K10D and is found on all the upper-line cameras since then.
camera, distance, ir, pentax help, photography, receiver
K-R remote advice please adwb Pentax K-r 8 02-01-2011 07:02 AM
advice on reliable use of IR remote? amoringello Pentax Camera and Field Accessories 3 12-15-2010 04:57 PM
Remote shutter advice please rotorhead Pentax Camera and Field Accessories 1 12-15-2010 01:10 PM
Using Harmony Remote for Pentax Remote mateojives Pentax Camera and Field Accessories 12 04-30-2009 11:29 PM
Advice Columnist Advice on Photography - do you agree? betsypdx General Talk 9 06-24-2007 12:45 PM
All times are GMT -7. The time now is 10:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
