02-01-2011, 12:53 PM   #1
Chinon 135mm f2.8 M42
Hi,
I have the mentioned lens in a M42 screw mount. The problem I'm having is that after I screw the lens on, I can't seem to set the aperture to the one desired. It basically stays wide open no matter how much I turn the ring. The switch on the lens is turned to Manual (M showing on the lens).
When I try to turn the aperture ring when the lens is dismounted it closes fine. Anyone knows what could be causing this?
Btw, my Takumar 200mm doesn't have this kind of problems.
02-01-2011, 03:17 PM   #2
ramseybuckeye's Avatar
I don't have a Chinon, but I'm sure you've tried setting it to auto, in case the lens marking is opposite of most. There is no pin getting depressed when screwed in is there? Something is changing when the lens is mounted, look closely when mounting it, compare the mount to your Tak.
02-01-2011, 06:39 PM   #3
QuoteOriginally posted by BeerBelly Quote
Hi,
Also, put a base cap on lens and try out aperture, if it works then it might be something on your camera mount. If it doesn't work, look at base of lens carefully, even with a magnifying glass and see if there is anything unusual
02-01-2011, 11:44 PM   #4
Thank you guys. I'll try it out today and let you know the results.
02-03-2011, 11:54 PM   #5
I seem to have solved the problem somehow or it solved itself :S
Anyway, if I hold the lens upside down (with the front end facing me) the aperture closes and opens just fine, even when mounted. So I'm thinking it must be something in the aperture ring that's a bit loose.
aperture, camera, chinon 135mm f2.8, lens, m42, pentax help, photography, screw
Chinon 200, 135, 35 (M42) - Experience? KjetilH Pentax SLR Lens Discussion 1 10-01-2009 10:36 AM
Chinon 135mm 2,8f losecontrol Pentax SLR Lens Discussion 1 02-12-2009 04:20 AM
Chinon 135mm 2.8 Question xfire Pentax SLR Lens Discussion 2 05-08-2008 07:10 AM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
