Originally posted by RioRico Are you thinking maybe of 'hyperfocus'? That's the point you'd prefocus to, in order to get a desired DOF. For instance, with a 21mm lens, if I set the aperture to f/11 and then prefocus (hyperfocus) to 2m, my DOF is from 1m to infinity. Or towards the other extreme, if I prefocus to 0.66m, then my DOF is from 0.5m to 1m. Such a hyperfocus trick can be played with any lenses, although shorter focal lengths give more leeway. Does that help?
I think i read it in one of scott kelby's digital photography books... will check it when I get home
randy
