02-01-2011, 11:13 PM   #1
iht's Avatar
Camera Lens Storage and Humidity?
I store my camera equipment in a plastic storage box (about 100cm x 50cm x 50cm). I recently purchased a hygrometer. I put it in the box to see what humidity reading I'd get. It reads between 55-65%. Is this a good reading? As in, is it too dry or too humid?
Or does different pieces of equipement require different values? I guess my ultimate aim is to prevent mould and to keep the gear in good shape.
Thanks in advance.
02-02-2011, 05:05 AM   #2
Going only from the settings on my dehumidifier, 55-65% is a bit damp.
Personally I'd be looking at adding silica gel packs to the mix! There are plenty out there that (a) change colour to indicate moisture, and (b) can be dried out again in a microwave or conventional oven.
Reading elsewhere 'ideal' lens storage apepars to be on open shelving, (although dust could be an issue).
02-02-2011, 11:02 AM   #3
KxBlaze's Avatar
I think ~60% is a bit too high. I have a cigar humidor and I have to keep my cigars around 65-70% which is considered high. For lenses I would try to bring that down closer to about 45% (just my guess). I have never read anywhere exactly what humidity lenses should be stored in.
02-02-2011, 11:18 AM   #4
Just1MoreDave's Avatar
Right now, my lenses are stored under these conditions:
Great for them, maybe not so great for me!
02-02-2011, 12:57 PM   #5
Ratmagiclady's Avatar
Dave wins!
I'd actually caution *against* sealing your stuff up too tight *unless* the moisture control in there is very good. Sealing that moisture *in* particularly in the dark* can be a bigger disaster than not doing much. Just take care not to do anything too hard for too long that way.
What I use for a budget solution is just filing cabinets with some dry-packs in there: (And a tub of Damp-rid in that room) it's not perfect, particularly when it gets kinda swampy down here, but it seems pretty sufficient. It was a perfectly-good solution up north when very humid days were pretty rare.
02-02-2011, 01:03 PM   #6
Ash
Community Manager
Ash's Avatar
Desiccators are your friend in these kind of conditions.
Use them liberally in the closed space the equipment is stored and you have the best chance of averting fungal infestation and mechanical degradation.
02-02-2011, 04:06 PM   #7
I store mine in plastic sealed bags with dessicant in each of them separately. But to be honest I have no idea if it is the best for the lenses. However, all my lenses are pretty cheap and nothing is very expensive so it should keep at least until I purchase the good ones. Just don't leave them in the car in a hot environment.
02-02-2011, 05:10 PM   #8
iht
iht's Avatar
Thanks for the replies guys! Sounds like I need more selica gels...
box, camera, pentax help, photography, storage
New accessories category for camera/lens storage DogLover Site Suggestions and Help 0 12-30-2010 03:50 PM
Camera storage - $25 solution Shibby3.8 Pentax Camera and Field Accessories 13 07-25-2010 03:47 AM
Camera/Lens Storage. glsmith Pentax Film SLR Discussion 3 01-31-2010 03:03 PM
Camera Storage question MSM Pentax Camera and Field Accessories 2 12-28-2007 07:59 PM
lens hoods, lens caps, UV filters and camera storage Ed in GA Pentax SLR Lens Discussion 4 12-22-2007 01:40 PM
All times are GMT -7. The time now is 09:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
