02-01-2011, 11:27 PM   #1
fccwpe's Avatar
SMC M 50mm f1.7 Loose front element
Need some help here.. bought an awesome lens at a swap meet, an SMC M 50mm f1.7. I pulled it out of my bag tonight and the front element, the part that extends when the focus is rotated, is loose and rattles. I can't find a screw to adjust it and don't know what to do to get it tight again. When I got it it was tight. Hmmmmm.... What to do??
Any suggestions would be appreciated!
02-02-2011, 02:39 AM   #2
Gareth's Avatar
It might just need the finisher tightened up. That the bit that goes around the front optic and has the white writing saying Pentax-M 50mm.......
To tighten it, get some blue tac, be liberal with it and make a sausage shape that goes all the way around the finisher, then turn upside down and press blue tac into something like a table and then whilst pushing down hard, screw the finisher back in tight
02-02-2011, 08:04 AM   #3
The rubber tip from a crutch works for that.
02-02-2011, 08:10 AM   #4
jeztastic's Avatar
I've had this happen to my m50 1.7. If it's the same as what I experienced, it's not the front element - if you check, the glass doesn't move at all - thankfully. If it is like this, you actually need to get the finisher off and tighten the tiny screws underneath. The finisher is a pig to get off - the way Gareth suggests sounds good. It screws all the way up through the filter/hood threads. Then you need a jeweller's philips screwdriver to tighten the screws. You may want to put a bit of glue on the threads, as mine is already loose again after I screwed a rather bent lens hood on it. Although you may not want to take the risk...
02-02-2011, 08:55 AM   #5
Gareth's Avatar
Them screws! Forgot about them! I once bought a lens off Ebay that was described as faulty as it rattled. When I got it I took the finisher off and I saw one of the screws had somehow come loose and was rattling around. Screwed it back in tight and it was as good as new
02-02-2011, 12:33 PM   #6
fccwpe's Avatar
You guys are AWESOME!!! Thanks SO MUCH!! It was the finisher and I had no idea! I used a pencil eraser to remove it and put it back on. The small screws underneath were tight so that was no worry. THANKS AGAIN!!!
02-02-2011, 01:58 PM   #7
Gareth's Avatar
Glad to help
50mm, 50mm f1.7, element, f1.7, front, pentax help, smc, smc m 50mm
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
sand on the front element of my tamron 17-50mm... chicomarks Pentax SLR Lens Discussion 5 11-16-2010 04:53 PM
Can dust go under front element? DA. NecroticSoldier Troubleshooting and Beginner Help 11 04-21-2010 01:40 PM
Pentax SMC-A 70-210/F4: Front Element Removal NeverSatisfied Pentax SLR Lens Discussion 4 12-28-2008 01:59 AM
All times are GMT -7. The time now is 05:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
