View Poll Results: Do you use a cable-release for your photography?
Yes! Quite often. 627.27%
Sometimes, but not too frequent. 1150.00%
Only a few times. 29.09%
Not at all. 313.64%
Voters: 22. You may not vote on this poll
02-04-2011, 08:51 AM   #1
Cable release options?
I have a pentax K-x and am currently searching for a cable release. I read from a random reviewer off amazon that the pentax k-x model is not compilable with any type of cable releases...is this true?
I am looking into getting this one: Amazon.com: Adorama Wireless Radio Remote Release - Camera remote control - radio: Electronics
But I'm not sure if I should. Please give me some help! I'm SO lost right now that it's not even funny... well, maybe it is a little funny lol
02-04-2011, 08:58 AM   #2
It's compatible with a remote, which is probably even better: Pentax Remote Control F 37377 B&H Photo Video
Have you considered one of those at all?
02-04-2011, 09:03 AM   #3
ajoe's Avatar
You should rename you post and be more specific.
A cable release and a remote are two very different items. I never us a cable release but often use a remote, so I did not answer your poll.
02-04-2011, 09:15 AM   #4
QuoteOriginally posted by ajoe Quote
I did rename the post to be more specific as you suggested...
I didn't even know there was such a thing as a remote until a few mins ago! I'm sorry that the poll is irrelevant to you and probably a lot of other people, unfortunately I can't seem to find a way to change the poll...so it will have to stay the way it is. =P
02-04-2011, 09:17 AM   #5
Hey, that looks real swell! I'll look into getting one of those. Thank ya kindly for your help it is very much appreciated :]
02-04-2011, 09:24 AM   #6
ajoe's Avatar
QuoteOriginally posted by NoobPhotographer Quote
I'm sorry that the poll is irrelevant to you and probably a lot of other people...
No need to be sorry. I was justing trying to help you understand that there is a difference and so your results may be skewed.
And yes, the remote is a very handy option, especially for tripod work.
02-04-2011, 09:56 AM   #7
chalion's Avatar
I used wired remotes on my K200D & K20D. I also have wireless remotes, but as often as I use remotes, I find that the batteries are usually dead - not a problem with my wired remotes.
02-04-2011, 10:12 AM   #8
QuoteOriginally posted by chalion Quote
The K-x can't use a wired remote.
Unless there is some reason to actually go Remote, you could also try the poor man's trip release. The timer. See page 131 of your manual.
02-04-2011, 06:12 PM   #9
Hypocorism's Avatar
Fyi: I couldn't respond to your poll because my 2 Pentax DSLRs don't support (wired, or radio wireless) cable shutter-release.
I don't think that Amazon-hosted unit (even ones that support some Pentax, which Adorama has 5 on this page below) could possibly work on K-r/K-x, the camera models have no PC-type aux port linked to the shutter like most other brands do across their range.
Wireless Radio Remote Release - Adorama.com
For info, here's several more types that we K-x/K-r owners luck out on also;
http://www.dealextreme.com/search.dx/search.remote%20shutter
I read (might have been here) a few weeks/mths ago some user had cobbled up their own electro-mechanical shutter activator, it was cheap, fairly simple and quite ingenious, IIRC comprising a solenoid operated lever and small receiver all attached and held on in the hot-shoe.
Another type used a mechanical plunger sheathed-wire method (ex old film camera type), attached to manually press the shutter button.
(a search on here, or Google, might uncover something)
Before we proceed further, please note: The K-x/K-r built-in IR Remote ability is definitely no substitute for wired-cable in practice. Although it can and does work within the usual crude limitations of IR (remember, IR != Radio Wireless even), plus the imposed limitation of only having a front mounted IR sensor on the camera body.
There are also important Pentax imposed limitations to take into account, such as IR delay, and that on a K-x remote shutter doesn't necessarily work fully or at all in conjunction with certain other modes/functions. Like HDR, remote Flash.
So; OK for basic use, just don't take it too seriously or have expectations beyond the above.
You can buy the genuine Pentax Remote F handset-control (listed in K-x manual, p291) for the proverbial pound of flesh at good camera outlets, or, can get 3rd party versions that work quite adequate, from eBay or DealExtreme from approx USD3.27 incl shipping.
DealExtreme: $3.27 InfraRed IR Shutter Remote for Pentax/Nikon/Canon/Sony/Minolta/Konica Digital Cameras (1*CR2025)
I use these universals for both my Pentax and Canon cameras.
(Nb; They activate shutter-only on Pentax, per the camera Drive Mode and Custom Menu settings, expect no other fancy features.)
.R.
02-04-2011, 06:52 PM   #10
SpecialK's Avatar
I am using a tripod more frequently (trying to expand my self-imposed limits) and yes, the remote is very handy.
02-04-2011, 09:10 PM   #11
Ex Finn.'s Avatar
I use a wired remote often. And always when hooked to a telescope.
02-05-2011, 02:32 AM   #12
Sometimes but not too frequent.
Always when using tripod (in combination with 2s timer)
05-08-2011, 06:41 PM   #13
shutter release cable for Pentax K-R
I too am looking for a shutter release cable for the Pentax k-r. I want to be able to open the shutter and then come back an hour later to see what I got. I am not willing to sit there with the ir remote and hold it open for an hour. Any ideas as what to do??? I just upgraded and figured that the k-r would be able to do it as my k100d super could. Any suggestions would be appreciated.
05-09-2011, 10:52 AM   #14
You're out of luck with regards to the cable release However I think the IR remote will do the trick. Check the functionality of custom menu 3, item 15. The manual is very brief about it (page 90 and 114) and I don't have a K-r.
And no, the K100D super is superior (and that is an understatement) when it comes to certain things; that is why it is called 'super' which stands for superior
05-11-2011, 01:39 AM   #15
Elva's Avatar
Location: Grahamstown in the Eastern Cape province of South Africa
Take a look in the DIY under pentax articles here on the fotum
cable, cable release, camera, k-x, pentax, pentax help, photography, radio, release
Options for remote shutter release for K-x Daniel_r Pentax DSLR Discussion 2 12-11-2010 07:09 PM
Cable release and SR sterretje Troubleshooting and Beginner Help 9 02-05-2010 02:30 AM
IR Remote v Cable Release channeler Pentax Camera and Field Accessories 20 03-13-2008 09:49 AM
Cable release for ZX/MZ-30? ftpaddict Pentax Camera and Field Accessories 0 02-04-2008 05:09 PM
ZX-L cable release options? scottax1 Pentax Film SLR Discussion 2 06-27-2007 06:59 PM
All times are GMT -7. The time now is 12:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
