Originally posted by bobmaxja If you use flash and you increase the shutter speed, the black stripe will grow. Normal the flash sync on Pentax is max at 1/180. Anything over 1/180 will show black stripe
Nothing wrong with the curtain
Look at the video link I attached.
the camera doesn't trigger the flash at speeds above 1/180th at all, so no worry about exceeding the max sync speed.
still looks like a trigger sync issue -- the triggers aren't able to keep up with the camera max sync speed. Try some fresh new batteries in the flash, commander and receiver.
