02-06-2011, 11:33 AM - 1 Like   #1
Aperture on Pentax-A lens
I'm using a Pentax-A 1:2 50 mm on a K200 on the AV setting.
On the lens itself, the f-stops go
2 - 2.8 - 4 - 5.6, etc.
When I control the aperture setting with the camera, the f-stops go
2 - 2.2 - 2.5 - 2.8 - 3.2 - 3.5 - 4.0 - 4.5 - 5.0 - 5.6, etc.
Can I use those intermediate apertures (like 2.2 & 2.5 for example) that aren't labeled on the lens?
When I manually change it, the lens goes from 2 to 2.8 with nothing in between. There is a stop between 2.8 and 4, however, even though it's not labeled on the lens.
Thanks in advance for your help
02-06-2011, 11:38 AM   #2
Yes, you can. You've got your camera set to show 1/3rd stops and that is exactly what it is doing. The actual stops on your lens are just where the "click" stops are. The actual; aperture changes incrementally inbetween the clicks.
02-06-2011, 12:33 PM   #3
Ash
Community Manager
Ash's Avatar
The clicks are as far as you can go with in-between apertures.
Some lenses have clicks that others don't. So yours cannot be set between f/2 and f/2.8, but can be set to f/3.5, which is half a stop above f/2.8 and below f/4.
The camera electronically sets the aperture for you when in A mode on the lens, so it's able to accurately set those intermediate apertures and bypass the manual stops.
02-06-2011, 02:18 PM   #4
Otis Memorial Pentaxian
Huh? My "A" lenses can be set in-between clicks if you really need to. The iris mechanism has continuous operation and will stop down based on ring position regardless of whether you are on a full/half stop notch or somewhere in-between.
aperture, camera, f-stops, lens, pentax help, pentax-a, photography
What is a good aperture rating for a zoom lens (or any lens)? justtakingpics Pentax SLR Lens Discussion 7 04-09-2011 06:32 PM
For Sale - Sold: Pentax - A SMC 35-105mm f/3.5 (constant aperture) lens (in great condition) portisrob Sold Items 1 12-21-2009 08:31 PM
For Sale - Sold: CPC 70-210mm f/4 KA-mount auto-aperture lens, Pentax SMC-A copy, Worldwide shi wallyb Sold Items 15 10-21-2009 03:16 PM
Pentax 67 and 67II lens aperture operation HarryN Pentax Medium Format 2 03-10-2009 08:31 AM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
