02-06-2011, 05:56 PM   #1
ismaelg's Avatar
How do I activate Live View on a K20D?
Hi,
I just borrowed a K20D and I don't have a manual. How is Live View activated? I can't find it....
Thanks,
02-06-2011, 06:13 PM   #2
imtheguy's Avatar
Its the spring loaded tab wrapped around the shutter button but it must be set up in the menu to engage LV. Suggest you download the manual from pentaximaging.com to understand the options you have to set up that button.
02-06-2011, 06:18 PM   #3
ismaelg's Avatar
Thanks!
02-06-2011, 07:04 PM   #4
I think you're going to be pretty disappointed in it's use (LV on the K20d) but note that the power switch slide can also be set to activate Digital Preview or My personal favorite, Optical Preview. Optical preview, in M mode, Stops the lens down so you can get a better idea of what your photo will look like in terms of DOF.
02-06-2011, 08:45 PM   #5
NeverSatisfied's Avatar
QuoteOriginally posted by JeffJS Quote
Yea I used to like using that function on my old Nikon F2 film body, too. Only problem is that sometimes the view is quite dark!
Ismael, in the menu, go to Custom Setting, number 30, "Preview Method". Then you can choose Live View, Optical (which shows the DOF like Jeff said), or Digital Preview.
02-06-2011, 08:50 PM   #6
ismaelg's Avatar
Thanks!
Just tried it out of curiosity. I don't see myself using it very often.
Thanks,
02-06-2011, 09:47 PM   #7
I use the optical in M mode with M type lenses. On the K7/K5 (don't have an M on the K20 to verify it), it activates the meter so one can dial the shutter speed, iso, and aperture while watching the affect it has on the meter. I prefer this method to using the green button. It also sometimes helps to nail the focus when using manual focus lenses. On my Olympus OM cameras, it's a button on the side of the lens that does it.
(not trying to talk anyone into anything, just discussing)..
camera, pentax help, photography, view
K20D Live View Problem hdsgem Pentax DSLR Discussion 4 12-26-2010 12:44 PM
K20D live view does not work mccarvindh Troubleshooting and Beginner Help 2 05-25-2009 11:05 AM
K20D - AF in Live View Pixguru Troubleshooting and Beginner Help 2 04-04-2009 08:50 PM
K20d Live View AF? HermanLee Pentax DSLR Discussion 16 02-19-2009 04:12 AM
live View on the K20D Ed in GA Pentax DSLR Discussion 3 04-05-2008 12:48 PM
All times are GMT -7. The time now is 12:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
