Originally posted by DaveHolmes I've not heard this to be much of an issue with the kit-18-55mm... Others may well have more comment on this...
OK, this would be issue for hihger level lense or if I would shoot something like macro, right?
Originally posted by DaveHolmes I tend to use multi-segment for general 'snapping'... Spot for low-light and night shooting and sometimes centre-weighted for well lit indoor people shots (I use centre-weighted rarely)
Although I don't think this is what Sterretje meant... I believe he was talking about making sure you are aware of which focus point the K-x is using...
Is this the same 5 or 11 or select one point focusing mode? I`m little confused here
Originally posted by DaveHolmes Press the 'OK' button in any shooting mode and you can set which of the 11 focus points is active OR you can set to the 2 'auto' modes (5 or 11)... This give the camera control of 'where in the frame' focus will be set... NOT RECOMENDED...
It doesn't help that the K-x's viewfinder has no visible (red square type things) focus points...
Most people tend to use centre focus point... lock focus and re-compose...
I always use one centered spot focus point (I select it in center). I lock focus with half pressed shutter speed, then recompose and shoot. Hmm, may be there is something with half pressed shutter speed? May be it`s not working on my K-x? Is there any settings which I may be on or of?
Originally posted by DaveHolmes Be aware that using a smaller aperture (higher f-number) will force slower shhutter speeds... You may have to compensate by bumping up the ISO... Although luckily with the K-x this isn't to much of a problem
Yes, this I know, if I change aperture by one stop, speed will change 4 times or something... This one is something I can compensate with ISO. Let`s see how it will go for me.... The worst thing is that when you travel, you don`t have lot`s of time to change settings, make control shoots, etc.
My idea (after your advices of course) is to use Av mode, to set lowest ISO which is 200, to set f/8 (or something) and then keep an eye on shutter speed. If it will go slower that 1/50, I`ll change ISO to higher number.
