Hi all, as mentioned in my last post i am looking for a zoom lens for distance nature shots. I am only a beginner so show winning shots are not essential. This is what ive found:-
Falcon 500mm ST Preset Telephoto Lens
f/8.0
for Pentax K
Falcon 500mm ST Preset is an amazing telephoto lens designed for photographing long range objects. The amazing power of this lens gives you the equivalent of looking through a pair of 10x power binoculars. Great for nature and astro- photography
SPECIFICATION:
- Focal Length: 500mm
- Aperture: f/8.0 - f/32.0
- Focus: manual
- View angle: 5º
- Filter size: 67mm
- Lens Construction: 4 elements in 4 groups, multicoated
- Length: 298mm
- Front Diameter: 70mm
- Weight: 640g
- Casing: metal
- Accessories: T-mount adapter for Pentax K / Samsung, pouch, lens caps, user manual
Many thanks for your help again for a newbie to the hobby
Sean
