02-09-2011, 07:13 PM   #1
Designosophy's Avatar
Tamron 28-200mm LD is short at 200mm
I just received a used Tamron 28-200 (model 171d) and as I compared images shot with the Tamron to images shot with my Sigma 70-300, I noticed that images shot with the Tamron were much wider angle at 200mm than those shot with the Sigma. They were comparable to about 115mm on the Sigma. I got out my Takumar 135 and found that it produced tighter shots than the 200mm Tamron. It is fine at 28mm. What is going on here? Do I need to return the Tamron?
02-09-2011, 07:24 PM   #2
The stated FL is good only at infinity focusing. Most zoom lenses "cheat" at the long end at close focusing distance.
Run your test again at infinity.
02-09-2011, 07:24 PM   #3
I doubt the discrepancy is that big, but +/- 10mm is probably an acceptable margin of error for focal length labels.
02-09-2011, 07:30 PM   #4
I know there is some variation in focal lengths, but this is huge. I'll check the infinity focus tomorrow. I seem to remember running into something similar, though not as drastic, before. Thank you.
02-09-2011, 07:54 PM   #5
KxBlaze's Avatar
I agree with Adam that +/- 10mm is probably ok but if your 135mm is tighter than the 200mm I would say that is way too much and unacceptable. I would do some more test just to be 100% sure and if you conclude that it is faulty, definitely return it.
02-10-2011, 09:02 AM   #6
I discovered that the manual was included in the packing materials. It explains the phenomenon under "Precautions in Shooting."
"Tamron AF 28-200mm (model 171D) employs an internal focusing (IF) system to achieve a remarkable .52 meter (1.71 feet) M.O.D. (Minimum Object Distance) at 135mm. Because of the characteristics of this optical design, the 200mm coverage, at distances other than infinity, is wider than that coverage of lenses using an ordinary focusing system."
02-10-2011, 04:53 PM   #7
I was able to confirm today that at or near infinity, the Tamron has the coverage of a 200mm lens. And it does a decent job for a fairly early autofocus lens. Not bad at all for $50. I'll have to add it to the lens database (this model isn't in there) and post a review after I've had it a while.
Last edited by Designosophy; 02-10-2011 at 04:55 PM. Reason: Additional information
200mm, images, pentax help, shot, sigma, tamron
Tamron 70-200mm f/2.8 vs. Sigma 70-200mm f/2.8 vs Pentax 50-135mm f/2.8 nah Pentax SLR Lens Discussion 27 12-08-2008 01:03 AM
birdie shots with short DA*200mm danielchtong Pentax SLR Lens Discussion 9 05-25-2008 06:09 AM
All times are GMT -7. The time now is 12:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
