01-07-2012, 05:10 PM   #16
Greetings! Regarding the nice Pentax FA 43mm f/1.9 Limited lens, I have not seen this issue (mine mounts fine on the K-5), however, I did find the following:
I thought I'd try using the lens' Aperture ring, so switched the lens out of "A" mode, and tried setting the aperture manually to, say, f/8. After doing this and looking at the Live View to move the Focus Selection Square over a certain area of the scene, I noticed it did not let me move it around in the subject area. Indeed, the Focus Selection square alternated between the square with 4 triangles, to the green expanding/contracting square). Nothing happened when pressing the "OK" button. To make this behavior disappear, I had to turn off the camera, switch back to "A" mode on the lens, power up the K-5 and then resort to setting the Aperture via the rear dial on the camera (in manual mode). Is this "normal" behavior for this lens on a K-5? Should one be able to use this FA lens in "Manual" mode with the Aperture ring? (This is my very first "FA" lens, and I did not change the default Custom Setting #27 (Using Aperture ring) And BTW, I find this FA43 to be exceedingly sharp at mid-apertures, even more so than my DA* 55, which is quite sharp as well! Thanks in advance for any expertise you may provide!
01-18-2012, 01:26 PM   #17
jpzk's Avatar
QuoteOriginally posted by stevelink Quote
Steve,
while I wouldn't dare getting into technicalities regarding this problem you have with the Fa 43 Ltd, and I hope someone will jump in and be able to assist you, I don't think I've encountered such problem myself.
I will just mount it on the K5 tonight and see if I can reproduce what you are experiencing.
JP
body, camera, fa, fa 43mm ltd, lens, ltd, pentax help
Bigma Fit is loose on body?? davekimber Pentax SLR Lens Discussion 14 05-20-2014 04:16 PM
Any site with complete list of what lens fit each camera brand? dinneenp Pentax SLR Lens Discussion 3 03-12-2010 10:51 AM
Modifying C/Y mount to fit Pentax K; hard, easy? excanonfd Non-Pentax: Canon, Nikon, Sony, etc. 2 01-20-2010 09:35 PM
Help me! Will this lens fit on a Pentax camera? JP_Seattle Pentax SLR Lens Discussion 6 01-09-2010 07:05 PM
will this lens fit my camera rob901 Pentax DSLR Discussion 5 01-25-2009 08:32 PM
All times are GMT -7. The time now is 12:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
