Originally posted by nandystam
Everything I read about the DA35 f2.4 sounds good. It's cheap but produces good results, and is a little bit closer to 50mm and a bit faster than the DA40. Does 7.5mm really make a lot of difference?
7.5 mm difference? Presumably you refer to focal length, and are also applying crop factor there, which can make waters murky.
Can I suggest using A.o.V (Angle of View) instead. That tends to give a more realistic, and accurate concept of the variance to be experienced between lenses in real world usage. Focal length never seems to translate to WYSIWYG comfortably.
A.o.V is included in the specs of each lens here;
Camera Lens - Official PENTAX Imaging Web Site
And perceptions are always a subjective thing, dependant on opinions and preferences; so for the visual graphic test with the only eyes that matter, yours, I find comparators can be fun to play with, try these:
Tamron Europe: Focal length comparison NIKKOR Lenses Simulator | Nikon Originally posted by nandystam
Help convince me one way or the other!!
You're going to buy it anyway. Just go ahead and lash out. You're a grown up now.
.R. -- Who intends to get 2.4/35 soon too, just because it's plastic.
