Originally posted by NeilsF Thanks for your quick reply. After seeing a suggestion in another post regarding e-dial problems, I switched aperture control to the front e-dial as an experiment (C menu item #25). Using the front e-dial, aperture control works perfectly. So, time to box up my 2 month old K-7 and send it off to the service center. Heavy sigh.
I'm somewhat puzzled with the fault. There is no mechanical link from the control wheel to anywhere, it just sends electrical impulses to the firmware like in "one click to the left", or "one click to the right".
In Tv mode, if you set Tv on the rear dial, do you see a similar behavior?
Could it be "a fluke" in the firmware? It's perhaps hard to believe that the firmware could have changed all by itself, but perhaps it would be worth a try to reinstall the firmware before you send the camera in. I have had one instance with my PC where a setting in my BIOS changed by itself (actually after quite a thunderstorm had rolled through our area), so hence my suggestion.
