Originally posted by slr_neophyte Sometimes, I get really frustrated being a glasses wearer when trying to get a nice clean full view through my camera's view finder. Does anyone else have problems with this? Any tips or suggestions? Should I just be wearing contact lenses whenever I plan to take pictures? This is particularly a problem at night, because I can never see everything I want to see in the viewfinder when I have glasses on (and using live view doesn't cut it either, at night)
I find it very out of touch how DSLR makers all seem to blissfully ignore this problem when it's so obvious that such a high percentage of their customers and avid enthusiasts for using their product would wear, and require vision aids.
Presumable you've adjusted the inbuilt diopter slider to the best position possible to suit your own vision impairment?
And here's the
been there, done that type of story:
My prescription is such that I could never get nearly enough adjustment for clarity with my specs on, though I could just see in the VF OK if the diopter was adjusted fully to the right if I took them off.
That created the problem of where do you put them temporarily? CR39 lenses always seem to scratch easily, frames are flimsy and easy to bend/break, or fall out of spare empty pockets when you bend over, so I had to start wearing a string-tether cord to hang them off my neck when removed.
OK, but problem only partially solved.
Still not satisfied, I then bought one of the Pentax VF magnifier part # O-ME53 to try, which gave very useful extra magnification, with added bonus that it also permits me to see in the VF clearly with my specs
on, plus the eyecup is softer and protrudes farther out making the camera less squashed against the face.
Pentax O-ME53 - Adorama.com
For me, that was definitely worth the money.
Pentax also make a "Diopter correction lens adapter M" replacement for the built-in diopter on the camera, which allows greater adjustment range. Plus a few other optional VF assist stuff here:
https://www.pentaxforums.com/accessoryreviews/category-Viewfinder-Attachments...ne-Pentax.html
So depending on your own prescription, one of those options could be worth considering.
There's also a 3rd party 1.3x/1.35x magnifier available to fit some Pentax. Try searching eBay.com on "KPS".
HTH.
.R.
