02-14-2011, 11:20 AM   #1
Deiberson's Avatar
KX Over exposing since Firmware Update
Seems like I'm having a lot of my shots coming up over exposed since I did the firmware update on my KX. Is this a common problem?
I shouldn't have to turn my EV down to -3 to have a balanced histogram in the semi auto and fully auto modes. What gives?
02-14-2011, 11:34 AM   #2
QuoteOriginally posted by Deiberson Quote
With ALL lenses? It Sounds like your aperture isn't stopping down.
02-14-2011, 11:37 AM   #3
Deiberson's Avatar
great. i just bought the lens off a guy on marketplace. and left + feedback.
what would be a way to confirm this?
---------- Post added 02-14-11 at 01:41 PM ----------
If the aperture is not stopping down, would this always be occurring or is it intermittent? Just so we're clear.....If I take a pic in P, or AT with the flash on Pttl, there is no way I should be overexposed, right? I'm posting pics in a few...
---------- Post added 02-14-11 at 01:59 PM ----------
here is a pic I took in auto mode. the flash was pttl.
how would this take place in auto? the entire lot came out like this. i don't get it. look at the exif info? the shutter was open for 1/8 of a second and there was a ton of light in the room and my iso was at 200??
exif here...click on the I on the photo.
02-14-2011, 01:53 PM   #4
The Exif says ISO 200, f9, 1/8sec, no flash, focal length 33mm. You can check the lens easily by taking it off of the camera. If it is an A type lens or one without an aperture ring, put it on A. That will stop the aperture all the way down. Flick the lever on the rear of the lens. The aperture should open and close without any delay (and without help).
What the photo LOOKS like is you are using a manual lens and firing the flash. In That case, P-TTL does not work and will fire the flash at full power regardless of the settings. Also, If it's a manual lens (no A on aperture ring or not a DA type lens without an aperture ring, or an M42 lens), the auto modes will take the picture with the lens wide open. I don't think that is the case though because the EXIF does report an aperture. The numbers the EXIF reports however, the photo should not look like that. If anything, if indoors, I would expect that photo to be Underexposed or very blurry from camera shake or both. In the case of an M42 lens (just for discussion) you can set the lens to M, dial your aperture, and use the Av mode. You just cannot control the aperture with the camera.
This all leaves me with the aperture is sticking (if it is a single lens). Try the other lenses you have and see if it clears the problem of over-exposure. If it does, then it's the lens. If it doesn't, the camera. Try reinstalling the older firmware or even the same one in the camera. I'm sure somebody here can point you to one if you don't have it anymore. (PS and DISCLAIMER: I accept no responsibility for anything that happens when I suggest loading a firmware). The other obvious things to try: Different card, format the card, try different batteries, etc to rule anything simple out.
02-14-2011, 02:42 PM   #5
Deiberson's Avatar
The lens is a Tamron 28-75 2.8 Its not a manual focus lens.
Worst case scenario....meaning the person who I purchased this lens from on the marketplace walks away from this and I'm left to pay for it...How much am I looking at to get it fixed?
I'm not saying the original owner won't take care of it....just wondering in case he doesn't
---------- Post added 02-14-11 at 04:46 PM ----------
I just took it off and twisted the Aperture ring. It stays open throughout the entire range and isn't stopping down. I'll contact the previous owner.
---------- Post added 02-14-11 at 04:47 PM ----------
02-14-2011, 02:52 PM   #6
You See that the Aperture is wide open and stays there regardless of what you do? I don't know what it costs to fix them. It may be under warranty and all you may need is a receipt to get it fixed. Tamron's USA warranty is 6 years. Don't know where you are though.
auto, firmware, kx, pentax help
KX firmware update kparkypark Troubleshooting and Beginner Help 10 04-28-2010 08:38 AM
Cannot Update Firmware a johnson Pentax DSLR Discussion 10 04-27-2010 04:36 PM
KX FIRMWARE UPDATE ntarbox Troubleshooting and Beginner Help 3 01-21-2010 04:18 AM
K7 Firmware Update Workingdog Pentax DSLR Discussion 2 12-22-2009 01:53 PM
Firmware update vievetrick Pentax News and Rumors 0 09-07-2006 12:20 PM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
