02-15-2011, 05:48 AM   #1
jeztastic's Avatar
Problems with focusing K10D, Katzeye
So,
I have bought a Katzeye for my K10D. I can't get the focus quite right.
To be honest, I'm not now sure what is the Katzeye installation or the K10D - they certainly disagree over what is in focus when. In some circumstances one will seem better than the other.
Basically, this is beyond my competance to sort out. Bearing in mind that I am in the UK, and that I have already spent more money than I have on the camera and screen, what are my options for sorting this out? My local family owned camera shop, whilst excellent, do not do Pentax.
Thanks,
Jez
02-15-2011, 05:56 AM   #2
It is a common problem. The thickness of the screen is not always quite right, which means that you will need a shim to correct it. Search this forum for the word 'shim'. The can be ordered from Pentax. I myself made my own from a plastic folder. Ugly but cheap. And it works.
Erik
02-15-2011, 05:57 AM   #3
Lowell Goudge's Avatar
what are the problems with the focusing.
My experience and from what I perceive on the forum is that installing a split image focusing screen in any of the bodies with a pentaprism, (like K10D) does not require any calibration, however there are shims available from pentax that permit shimming the screen to correct focus errors, it is just rare that the K10D would need them
Also contact Rachel Katz because they have excellent support and can probably assist also.
One last point, you did install it the correct way around, with the tab on the right as you face the lens opening, and you did take off any protective plastic.
Sorry, but had to ask
02-15-2011, 06:05 AM   #4
jeztastic's Avatar
Yes, it was the right way round...
I guess that I was expecting no problems as well, part of me wonders if it is seated correctly, as I found it a bugger to fit. The thought of putting shims in horrifies me, it was hard enough just getting the screen in without the camera filling up with dust or getting scratched...
I guess my other worry is about front or back focusing in the K10D. The easiest way of checking that the screen is installed correctly is to compare it with the AF indicator, but if this is off too...
02-15-2011, 06:58 AM   #5
QuoteOriginally posted by jeztastic Quote
actually the easiest way to check the screen is to focus on something and forget all about the AF indicator.
You are putting the screen into the camera I assume to focus manually, why bother with the indicator.
ALso, while the level of effort to put a screen in can vary from person to person, I find it hard to understand it being a bugger to fit.
My first screen took all of about 1 minute to change, that was swapping between *istD and K10D to prove a point of metering, then I swapped them back.
I have since installed split image screens in both the K10D and *istD with no issue, and only a minute or so each
No scratches, no dust. It is a relitively easy task to perform as long as you have a good set of tweezers
02-15-2011, 09:45 AM   #6
sterretje's Avatar
Both my K100D and K10D had to be shimmed.
Install was done by my dealer. I eventually replaced the K10D one with the original as the split screen was too far off. From this last experience I can feel for jeztastic. I'm a bit nervous when it comes to these things which basically results in a bit of a tremor when trying to fit the screen.
For the shimming I took the cameras to the local Pentax repair facility. For the K100D they did it for free as part of a cleaning / check, for the K10D they charged me a 'minimal' amount.
02-15-2011, 10:07 AM   #7
My experience would be similar to Lowell.
Very easy to do and fast to do - fear is your main enemy!
Additionally, I am happy to use the AF indicator as confirmation of my manual focusing.
camera, focus, k10d, katzeye, pentax help
For Sale - Sold: Katzeye focusing screen - K10D/K20D (US/CAN) dugrant153 Sold Items 4 09-16-2010 11:38 PM
For Sale - Sold: Katzeye Focusing Screen for K10D (K20D) rormeister Sold Items 0 08-01-2009 03:00 PM
For Sale - Sold: Pentax K10D/K20D KatzEye Focusing Screen pawzitiv Sold Items 2 06-13-2009 11:26 AM
Katzeye focusing screen driver381 Pentax SLR Lens Discussion 3 01-26-2009 12:18 PM
Katzeye Focusing screen eccs19 Pentax SLR Lens Discussion 12 01-16-2009 03:34 PM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
