02-18-2011, 08:03 AM   #1
updating firmware
I am planning to update the firmware in my K110d in the near future. Any thing I shoul;d be aware of before making the attempt. Thanks for your help in advance.
02-18-2011, 09:06 AM   #2
KxBlaze's Avatar
When I updated my Kx I was told to use an AC adapter (if possible), if not then make sure to use brand new lithium batteries, to make sure your camera does not shut down due to power loss. Use a freshly formatted memory card and lastly make sure you do not hit any buttons or turn the camera off until the update is completely done.
02-19-2011, 08:47 AM   #3
Hypocorism's Avatar
QuoteOriginally posted by gimp Quote
Read the instructions fully on the download webpage that I have supplied below and follow them exactly, step by step. Have it onscreen for reference when you do the update on the camera.
And if you do that, have no fear, everything will be easy and go smoothly. Done.
Software Downloads : Support & Service : PENTAX
HTH.
.R.
02-19-2011, 04:01 PM   #4
I don't know what the root directory of the sd card is. Please advise---thanks
02-19-2011, 07:44 PM   #5
Hypocorism's Avatar
Root directory means base, parent, main or core directory, that holistic storage container-space of the card that exists directly at the drive letter assignment of the card.
Sub, or Branch, directories are typically contained and visible within the root directory, also files can be placed there too for storage.
Root directory - Google jM
.R.
02-20-2011, 01:25 AM   #6
Wombat's Avatar
Just to be absolutely clear on that, when you insert your SD card into your card reader, it will normally come up on your computer monitor showing a folder called DCIM, which contains folders with your photos in them. On a freshly-formatted card it'll just be blank (no DCIM). To update your firmware it's strongly recommended that you use a freshly-formatted card, so when you open it up you'll just see a blank. Put your update file there. That's the root directory. As others have said, follow the instructions carefully, take your time and in 90 seconds or so you'll have an updated camera. It will now make you a cup of coffee, massage your feet and put you to bed. Unfortunately, it won't print dollar bills. We're all waiting for that one...
02-20-2011, 10:01 AM   #7
QuoteOriginally posted by Wombat Quote
... an updated camera. It will now make you a cup of coffee, massage your feet and put you to bed. Unfortunately, it won't print dollar bills. We're all waiting for that one...
Will it brew beer for me?
02-20-2011, 10:54 AM   #8
Hypocorism's Avatar
QuoteOriginally posted by cats_five Quote
That option's only available in the Xtra Pro Mk IV Limited Edition Special model if you order a double side serving of French fries with the camera on tuesdays between 12 and 2 pm.
.R.
02-20-2011, 12:24 PM   #9
Thanks all for your assistance. The first attempt did not work. I reread the instrctions and found out where I was going wrong and was successful on the attempt. Thanks again----Tom
firmware, pentax help
updating firmware on ist dl war eagle Troubleshooting and Beginner Help 4 05-03-2015 08:50 PM
Updating Firmware on K-7. ronin67 Pentax DSLR Discussion 3 12-24-2009 10:19 PM
Firmware Updating to 1.30 Jesus Pentax DSLR Discussion 7 05-24-2008 07:01 PM
updating firmware MikeD Photographic Technique 4 03-23-2008 05:24 PM
updating firmware CeeBee Pentax DSLR Discussion 3 12-09-2007 04:53 PM
All times are GMT -7. The time now is 07:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
