Originally posted by padraigr Hi I'm leaving the point & shoot world for the dslr world & I have been looking for quite a while & am still struggling to make a decision, but I do like what the kr offers. I want a good all rounder that is not to difficult for a novice , can give reasonable video & is particularly good at sports photography. Can anybody pass on words of wisdom about this camera particularly anybody that has personal experience of it. Many thanks
Hi,
Before you spend money on any DSLR, let me play the devils advocate here.
I do this because I have seen so many posts of new users on this and other forums complaining and being disappointed by the results of they newly purchased DSLR...
I don't know why I trow this all at you and not one of the other people seeking advise, guess you are just lucky
There are a few things you should be aware off I believe:
1) A DSLR is capable of making much better photos than a point and shoot camera mainly because of the much larger size of the image sensor.
Mostly you see the differences in: colours, dynamic range (amounts of detail in dark and light areas), noise and detail.
The fact that it is capable of making better photo's does not mean that it will.
A DSLR by default does less in camera processing: less sharpning for instance.
It preserves more detail and leaves sharpning and the like to postprocessing or the user to change the default in camera processing settings (and there are many...)
2) Lenses can be changed on DSLR's, there is a lot of quality difference here.
P&S camera's can have 16Mpixels, however most often the lenses they have, have less resolution.
You'll find phones with 12Mpixels and a tiny plastic lens; madness!
Medium or high grade DSLR lenses however can outresolve the camera sensor.
3) There is a direct relationship between the size of a lens and the size of a sensor.
I.e. in order to achieve the same maginification, zoom range etc one needs a lot bigger piece of glass on a DSLR than on a P&S camera.
It is nearly impossible to make a 25x zoom lens with a good enough aperture for a DSLR.
Prepare to invest in glass after this purchase! You'll be carrying a lot more stuff with a DSLR, many people also have a small P&S for occasional use.
Be aware, larger lenses are much more expensive to make...
4) The better the camera resolution, the more flaws you will see.
It is like looking at an old Video 8 recording on a High Def TV.
It looked ok 20 years ago, now it sucks.
Often people display the photo's of their new DSLR on the 24" computer screen, magnify it to the max and see flaws. It will still be not perfect.
5) No DSLR can beat a HD camcorder still.
Do not expect to buy one product that does both well. Never mind the sales people.
There are some camera's that do photo and video reasonably well (Lumix), but you'll still loose image quality and lens flexibility.
The most important thing IMHO to understand is the mind trick.
Besides all the important stuff like: composition, shadows, rule of third, people expect the technical output of the photo to be better.
That's what they've paid for.
An DSLR is much more expensive, so it should deliver more detail, sharpness.
Many expect perfect results "out of the box", better than their old P&S.
However, better results cannot only be delivered by a better sensor and a better lens. Next to that a DSLR is a more complex machine, more can go wrong.
You should get some minimal understanding of photography to make it work.
Terms like: Shutter speed, ISO and Aperture should be not only familiar, but also you should understand the effect they have on your photos.
There is enough info on the Internet, books etc.
The full auto or scene modes on the camera can help you and if you are less experienced, use them.
Then learn to tailor it to your needs and to understand the camera in its details.
On the K-x vs K-r choice, buy the K-r, it comes with a LiIon battery and focus indicators in the viewfinder.
For me enough reason the pick the K-r.
Make sure you find yourself a pair of sharp and good lenses over time.
But most of all, try to understand what the camera does when you press the button.
Wow! This has become a much longer post than I intended when started.
Hope it did not scare you off
Buy the camera, and a book, and perhaps you'll become one of us. Hobbyists with a passion for photography
- Bert
