02-21-2011, 09:33 AM   #1
Safe Flash Equiptment for K7/AF240Z&AF280T
Hi, I have a feeling this has probably been discussed..but i couldn't find anything relating to the k7. I am very clueless about how the voltages work in anything...so I just wanted to be on the safe side, as I have been advised to take caution in using older flashes with the k7. The two older flashes I have is the AF240Z and the AF280T. Thanks!
Nick
02-21-2011, 10:49 AM   #2
WiseOx's Avatar
Hey Nick, sorry, I owed you an IM back on this.
From what I've read, you should be fine with those flashes, but it still wouldn't hurt to invest in a voltage meter and test for yourself before using. Every man should have a voltage meter in his toolbox.
I have a bunch of manual flashes, but never bothered testing them, as all are used off camera, with wireless triggers.
I assume you've also read, and understand that those old flashes, even if they are low voltage, will only work in manual mode, on camera. No PTTL.
Cheers.
02-21-2011, 11:24 AM   #3
Yea, I think it wouldn't hurt to have one around the house, going to pick one up later, will also provide me with peace of mind too before i use the flashes. thanks Doug!
02-21-2011, 12:28 PM   #4
Ex Finn.'s Avatar
AF 280T is safe to use, reads 7.2vdc. Don`t have a 240 so no comment on it.
02-21-2011, 08:40 PM   #5
gebco's Avatar
I have the 240Z and have used it safely on my Sony V3 and my K-x. You can check the voltage here:
Photo Strobe Trigger Voltages
02-21-2011, 10:33 PM   #6
Thanks for that site, that brought me peace of mind when using the flash. thanks again!
02-22-2011, 01:37 PM   #7
Ira
I'm on my iTouch now and can't post the link, but if you ever come across a bargain old flash and you're worried about voltage, Photodiox now sells a SafeSync adapter for just 16 bucks, as opposed to 50 plus for the Wein. You can find it on Amazon.
camera, flashes, k7, pentax help, photography
For Sale - Sold: AF280T Bounce Flash w/adaptors & AF080C Ring Flash (US/UK/CAN/AUS) MJL Sold Items 3 02-07-2011 10:19 PM
Will the flash AF240Z work with the Kx? The Kurly One Troubleshooting and Beginner Help 8 04-08-2010 11:13 AM
Best $30 Flash (AF280T) i ever bought philbaum Flashes, Lighting, and Studio 7 12-15-2008 07:16 AM
pentax AF240Z flash & *ist DL2? York DL2 fan Flashes, Lighting, and Studio 3 01-19-2008 08:11 AM
All times are GMT -7. The time now is 12:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
