02-21-2011, 03:45 PM   #1
P-TTL does not work correctly with K-5 and Metz 54MZ-4i
I recently purchased Metz 54MZ-4i Digital and SCA 3702 M3 for my PENTAX cameras.
I set the flash mode to TTL to use P-TTL mode.
It works just fine with K-x.
But it does not seem to me that it does not work correctly with K-5 since the picture I took was extremely over exposure.
I took the pictures using P mode on both K-x and K-5.
I wonder if this issue happens on my own K-5 only.
Can anyone here use Metz 54MZ-4i Digital with K-5 in P-TTL mode without any problem?
02-21-2011, 04:02 PM   #2
NicoleAu's Avatar
I vaguely remember reading somewhere that Pentax was working with Metz to fix a problem with K5's and the Metz flash. Maybe try doing a google search for your issue?
02-21-2011, 04:25 PM   #3
monochrome's Avatar
QuoteOriginally posted by gomazo55 Quote
Try PM'ing MattDM. he's the local flash expert on the Forum.
02-21-2011, 06:54 PM   #4
I don't have the flash nor the camera body in question....
I suspect the flash is not in p-TTL mode.
Try this: put the flash and the camera in p-TTL mode, put the camera in 2 second delay mode. Hit the shutter release. You should see:
1. A weak strobe (preflash) from the flash.
2. The mirror being lifted.
3. 2 second delay
4. The shutter opening, and a strobe (main flash) from the flash, then the shutter closing.
If you don't see (1), it's not p-TTL mode.
Please post back.
02-21-2011, 08:56 PM   #5
Thank you for your reply. Unfortunately I could not find any issue relative to Metz 54MZ and K-5 using Google.
But I could find the chart placed on the following link:
http://www.beco.is/lisalib/getfile.aspx?itemid=6137
According to this chart, 54MZ-4i with SC3702 M3 supports PENTAX K-5.
So my K-5 itself might be something wrong.
02-21-2011, 08:57 PM   #6
Thank you for your reply, Monochrome-san. I will try sending PM if I can not fix it.
02-21-2011, 09:03 PM   #7
QuoteOriginally posted by SOldBear Quote
3. 2 second delay
Please post back.
Thank you for your advice.
I tried using 2-second delay with 54MZ-4i, and I could see preflash just after I hit the shutter release.
So I think that P-TTL is activated.
02-22-2011, 12:20 PM   #8
aleonx3's Avatar
I doubt very much that Metz would support PTTL, may be TTL but that is different.
02-22-2011, 03:49 PM   #9
QuoteOriginally posted by aleonx3 Quote
I'm curious....
Care to elaborate?
According to Metz on their website, the 54MZ-4i with appropriate module does support Pentax p-TTL.
02-22-2011, 04:07 PM   #10
I'm curious....
Care to elaborate?
I was actually going to say the same thing and in fact Did. Then I went and looked at the Metz site and Pentax P-TTL is in fact listed (at which point I deleted my post). However if you look at the manual for the flash, it doesn't appear to mention P-TTL at all (though I didn't read every word in the manual). Confusing because, my 58 AF-1 manual does specifically discuss P-TTL and in fact, it is an option on the menu (mode) when mounted on the camera. When the flash is Off of the camera, P-TTL is not in the menu system of the flash.
02-22-2011, 04:48 PM   #11
Does Metz 54MZ-4i support p-TTL?
According to these articles, with SCA 3702-M2, it does (note that Matt's articles say "No p-TTL Wireless," not "No p-TTL."):
- The Definitive Guide Metz P-TTL Flash Models.
- The Definitive Guide Metz P-TTL Flash Models Metz Mecablitz 54 MZ-4i Digital.
- Mecablitz 54 MZ-4i Digital - Product Information.
- Pentax K10D & Metz 54MZ-4i compatability? (particularly last post in the thread).
My guess is that the Metz 54MZ-4i manual does not mention Pentax p-TTL because at the time of print, module SCA 3702-M2 didn't exist.
02-22-2011, 05:08 PM   #12
I'll take your word for it. I was just pointing out what I saw at the Metz website.
02-22-2011, 05:12 PM   #13
Thank you for your reply. I have confirmed with Metz Technical Support that Metz 54MZ-4i Digital with SCA 3702 M3 Adapter supports P-TTL and PENTAX K-5.
02-22-2011, 05:15 PM   #14
Thank you for your reply. About P-TTL, it is described in the manual of SCA 3702 Adapter. If we set the flash mode to TTL, P-TTL is enabled.
02-22-2011, 05:16 PM   #15
QuoteOriginally posted by JeffJS Quote
Thank you for your replay.
I have confirmed with Tech support that Metz 54MZ-4i Digital supports P-TTL.
I is also described in the manual of SCA 3702 Adapter.
k-5, k-5 and metz, k-x, metz, mode, p-ttl, pentax help
K-7 flash in Wireless mode. Doesn't work correctly? Edvinas Pentax DSLR Discussion 7 09-07-2010 06:14 PM
Metz 58 AF-1 underexposure in P-TTL roelof Flashes, Lighting, and Studio 9 02-15-2010 12:52 AM
Metz 48 P-TTL wireless display Arpe Flashes, Lighting, and Studio 4 12-12-2009 08:19 AM
Pentax K10D & Metz 54MZ-4i compatability? rrobinson54 Flashes, Lighting, and Studio 6 08-28-2009 02:45 AM
All times are GMT -7. The time now is 10:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
