02-22-2011, 06:58 PM   #1
jonhock's Avatar
Keeping Exif Info Intact
Concerning Pentax day. Could anybody explain how I make sure that my Exif information stays with the photo when I upload to the Forums?
Thank you
02-22-2011, 07:02 PM - 1 Like   #2
pixelsaurus's Avatar
Resizing for web in Elements 6 will guarantee that your exif info will be stripped.
02-22-2011, 07:04 PM   #3
jonhock's Avatar
Then I would guess that the same would be true of Elements 7?
02-22-2011, 07:33 PM - 1 Like   #4
SpecialK's Avatar
Pretty sure any "save for web" will kill it.
02-22-2011, 07:33 PM - 1 Like   #5
Don't resize for web with Any software. Instead, do a simple resize. I don't know how elements handles it but every version of Photoshop I've used, there is an Image Size option in the IMAGE drop down menu.
When you resize make sure your largest dimension is less than 1024 pixels. That way when you upload it, your exif should remain in tact.
02-22-2011, 08:13 PM   #6
It's the 'Save for Web' assistant that drops the EXIF info, not the actual resizing which you may have achieved in a variety of methods. So do a "Save as" instead of using the 'Save for Web' dialog
02-22-2011, 09:19 PM - 1 Like   #7
In the gimp,
menu file -> save as
in the 'save image' dialog, specify new filename and click save
a new dialog window with title 'save as jpeg', opens
expand the advanced options and make sure that you have checked the tickbox for 'save exif data'
done; just open the file in a viewer to check
02-22-2011, 09:48 PM   #8
jonhock's Avatar
OK, here we go....
Thank you all for a really fast response!!! With this photo, I'm using elements 7 with the Image adjustment instead of the "save for web". I call the photo"Kinda Contrasty"
Or maybe I should (With all of you guys fantastic help) call the photo: "Problem solved !!"
Oh, and by the way, all I did was resize it. That really is the color of the building!
PENTAX K10D  Photo
02-22-2011, 11:05 PM   #9
Great.
Looks by the way as if you have a spec of dust on the sensor in the left top corner of the image
02-23-2011, 06:13 AM - 1 Like   #10
Hypocorism's Avatar
QuoteOriginally posted by jonhock Quote
Thank you
Put this in your toolbox to get around all the senseless crapware that butchers it.
ExifyMe.
XtraSimplicity Blog Archive ExifyMe
And like sterretje says; Clean that dirty sensor!
.R.
02-23-2011, 10:24 PM   #11
jonhock's Avatar
nag, nag, nag....
From
sterretje
"Looks by the way as if you have a spec of dust on the sensor in the left top corner of the image"
QuoteOriginally posted by Hypocorism Quote
If ya look really close, you will see that that is an eagle flying off in the distance...
OK, how about this- That's what I get for changing lens on a city street with the wind blowing
Thanks guys, there was actually more than one spot. Gotta love that mirror lock-up!
PENTAX K10D  Photo
camera, exif, exif info, pentax help, photography
Questions about RAW exif info and EV Deiberson Troubleshooting and Beginner Help 19 01-18-2011 10:40 PM
Lost EXIF info Gillies Troubleshooting and Beginner Help 5 01-13-2010 03:46 AM
EXIF Info Question navcom Photographic Technique 7 06-26-2009 05:55 AM
AF Info in EXIF useful for anything? morfic Pentax DSLR Discussion 9 06-18-2008 08:56 PM
Keeping EXIF after PP slowpez Digital Processing, Software, and Printing 20 06-05-2008 01:51 PM
All times are GMT -7. The time now is 06:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
