02-23-2011, 09:54 AM   #16
ironlionzion's Avatar
On a side note, while taking that picture of the lens, I found several fungus growths on my panagor macro....time to put him out in the sun. The fungi are all on the perimeter of the glass, so it seems like it hasn't affected the image...yet.
05-20-2011, 11:35 PM   #17
nanhi's Avatar
It is very easy to dismantle the front and rear elements of a lens yourself. No expensive tools are required. You can borrow a pair of calipers from a workshop or dividers from the geometry box set of a school going child.
Some front element requires a piece of truck rubber tube and a plastic water pipe 6 inch long (for firm grip) with a proper internal diameter. The lens retaining ring screws out with the force of friction. You may need to apply a tiny bit of WD40 with a toothpick around the diameter of the ring for old lenses.
Then use ROR lens cleaner (purchase it from Adorama for $ 9) and try to clean the lens. If the spot remains, send the lens to Mr. Mukul Garg:-
Optical Components,Optic Lenses,Infrared Optical Filters,Meniscus Lenses Manufacturers
mukul garg uniopt@hotmail.com
UNIVERSAL OPTICS.
D-1, INDUSTRIAL ESTATE.
ROORKEE - 247667.
(UTTARAKHAND)
INDIA
He is more than 50% cheaper than that famous co. in the US. Also he is an Industrialist and a highly educated Engineer - few words and no advertisements.
The US Co. talks a lot, frightens you with much negative blah blah about damaging the lens and ends up with charges that leaves a hole in your pocket.
Have attached a photo of my damaged lens that was returned back to me like a shining jewel, new coating and all.
05-21-2011, 02:15 AM   #18
kh1234567890's Avatar
QuoteOriginally posted by nanhi Quote
A thin disposable rubber glove wrapped round an old plastic rear lens cap works fine for me - not having a truck handy to disassemble
As for the original question - those look like dried up water drops and should come off easily once you get to them.
05-21-2011, 09:00 AM   #19
nanhi's Avatar
Great idea KH. Just that in Bangalore it is very easy to get a piece of truck tube rubber from the roadside Tyre Puncture Repair Shops absolutely FREE. Thanks God I was spared from having a Truck handy to disassemble one.
Once I even used a thick double sided scotch tape. I find a piece of tyre tubing safe as it is not easy to puncture and damage the lens retaining ring.
I have seen hollow rubber bungs in various diameters with my local camera repair shop, but these cost a lot.
11-05-2021, 06:55 AM   #20
I was searching for information about a lens I own and ran into this 10 year old thread. Did you resolve the problem with the hundreds of dots on the front element of your Porst 1.2?
11-05-2021, 07:18 AM   #21
Banned
QuoteOriginally posted by SkiBum Quote
Last post was from 2016!
So try contact via email.
dots, element, front, pentax help
Opening the front element on a Pentax-A 28-80 Clinton Pentax SLR Lens Discussion 9 05-04-2010 06:27 AM
Can dust go under front element? DA. NecroticSoldier Troubleshooting and Beginner Help 11 04-21-2010 01:40 PM
Replacing front lens element apisto Pentax SLR Lens Discussion 29 11-20-2009 04:27 PM
Rotating front element DUH! dws1117 Pentax SLR Lens Discussion 9 04-28-2008 05:13 PM
Front element spots Ash Pentax SLR Lens Discussion 9 05-02-2007 12:58 PM
All times are GMT -7. The time now is 11:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
