02-22-2011, 06:59 PM   #1
ironlionzion's Avatar
Hundreds of small dots undernearth front element
Hi I recently got a Porst 1.2, but I noticed it has a ton of very small dots under the front element. They are pretty uniformly spread out and some look like they are in a straight line. Again, they are incredibly small and can only be seen at a certain angle. Any ideas what they could be?
02-22-2011, 07:29 PM   #2
Dust?
02-22-2011, 07:32 PM   #3
SpecialK's Avatar
Sample?
02-22-2011, 07:39 PM   #4
I'll get pics up in an hour. there are literally thousands of little white dots
02-22-2011, 07:42 PM   #5
If it's on the outside, then it's just dirt/water and can be cleaned. If it's underneath, then it's probably fungus or haze.
02-22-2011, 08:31 PM   #6
heres the dots
02-22-2011, 08:48 PM   #7
Ole
Ole's Avatar
Could it be stains from a spray of water or cleaner? Try to wide it off with lens cleaning tissue and lens cleaning fluid. That can't harm and perhaps that'll solve the mystery.
02-22-2011, 08:54 PM   #8
At first that's what I thought. But when I tried cleaning it it was apparent that these spots are underneath the lens.
02-22-2011, 09:08 PM   #9
Ole
Ole's Avatar
Deterioration of the lens coating? It doesn't look like fungus at all.
02-22-2011, 09:15 PM   #10
How thick is the lens coating? The spots, although you can't tell from the photograph, look to be around a mm under the surface. It's very hard to say though.
02-22-2011, 09:15 PM   #11
Wheatfield's Avatar
It isn't air bubbles in the glass is it?
02-22-2011, 10:28 PM   #12
Looks like element separation to me.
02-22-2011, 11:51 PM   #13
I'm more willing to bet that someone has taken this lens apart before, Tried to clean it and did a shitty job of it. What kind of lens is it? I agree, it looks like dried water droplets or something like that. Just on the inside rather than the outside.
02-23-2011, 08:50 AM   #14
Talking to the previous owner, apparently someone did open it up. It does look like little water spots, which often can form those straight line patterns. I'll have to buy a half mm flat head screwdriver to take the front element off and check.
02-23-2011, 09:00 AM   #15
Spots = spray = mist = aerosol of oil fractions from helicoid grease breakdown?
In any case, options are to leave it alone while watch to see if it gets worse, and, to open the lens and clean it. I would leave it alone. To clean I'd try removing and cleaning the front element first, as an indication of how the remaining elements will 'clean' -- if front cleans well, I'd clean as many elements as I can within my skills.
dots, element, front, pentax help
Opening the front element on a Pentax-A 28-80 Clinton Pentax SLR Lens Discussion 9 05-04-2010 06:27 AM
Can dust go under front element? DA. NecroticSoldier Troubleshooting and Beginner Help 11 04-21-2010 01:40 PM
Replacing front lens element apisto Pentax SLR Lens Discussion 29 11-20-2009 04:27 PM
Rotating front element DUH! dws1117 Pentax SLR Lens Discussion 9 04-28-2008 05:13 PM
Front element spots Ash Pentax SLR Lens Discussion 9 05-02-2007 12:58 PM
All times are GMT -7. The time now is 08:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
