Hi. For starters, about controls: which camera are you using? They're pretty similar, but it'd help if you were more specific about your questions.
From the sound of it, about rectangles, you may mean the autofocus point selector. The green square means the camera's computer will choose a focus point, SEL means you can select the focus point with the 4-way keypad, and the other one means the AF will only use the center point.
As for your Promaster lens, (I'm going to go with Ep's notion you have to be above 200mm rather than lower: I thought I'd remembered the other way around,) that's just how the lens is designed, though.
And AE-L will just hold a meter reading (what the camera's automation chooses for exposure in any automated mode) while you *recompose.* Decomposing is to be avoided while doing photography. Many of us are lifelong photographers, but there's always the next incarnation, if that's not enough. Many Pentaxes will in fact last more than one lifetime, but remember you are mortal.
