02-26-2011, 12:39 PM   #1
Shaking by shutter movement
Hello, I got this issue when shooting pictures, sometimes my camera shakes on my tripod because of the shutter snapping a shot (on stable ground) and i'm like taking a long ranged close up at that moment... so tell me guys how can i improve from this?
02-26-2011, 01:10 PM   #2
K(s)evin's Avatar
Use your 2 or 10 second timer OR a shutter release cable.
02-26-2011, 03:08 PM   #3
ramseybuckeye's Avatar
You can use the mirror up function so the mirror is up before the camera takes the photo, at least the K20D has this. Check your manual on how to use it. I never take a tripod shot without a remote, you can get the Pentax Remote Control F or lots of cheap imitations on ebay, etc that work fine. Hopefully your tripod and head are sturdy, some bounce with the slightest touch.
02-26-2011, 03:09 PM   #4
Hypocorism's Avatar
QuoteOriginally posted by K(s)evin Quote
Ditto. Or a wireless remote release set on 3 secs:
http://www.dealextreme.com/p/wireless-ir-remote-control-for-sony-canon-nikon...1-cr2025-50684
... and get a much more stable tripod setup! The camera should not be able to shake it too.
Those are the only options I can see ATM.
.R.
02-26-2011, 03:25 PM   #5
I got a k-5 and i'm really not touching my device it's the moment when it's snapping itself but i could check up for that mirror function
02-26-2011, 03:33 PM   #6
wlachan's Avatar
2s timer is mated with mirror pre-fire. If that doesn't work, you may need a better tripod.
02-26-2011, 03:35 PM   #7
The shutter should not make the tripod shake. If it does get a better tripod. However, mirror slap can be solved by mirror lock up. But have you tried turning off shake reduction as slight movements can cause the sr to autocorrect where it shouldn't. Manual mentions this and advises not to use sr when on a tripod. Could solve your problem.
02-26-2011, 03:40 PM   #8
wlachan's Avatar
SR is turned off by 2s timer by default.
02-26-2011, 03:52 PM   #9
Wheatfield's Avatar
QuoteOriginally posted by saltshakalickalime Quote
What lens, what tripod and what head?
Also, is the rig mounted to the tripod by the lens or body?
02-26-2011, 04:25 PM   #10
SR is also turned off when remote is activated
02-26-2011, 05:03 PM   #11
Yes you both are correct that sr turns off in those conditions. I just wanted to mention that just in case the poster was trigger by hand. They didnt mention if they were or not.
02-26-2011, 07:27 PM   #12
bobmaxja's Avatar
What kind of tripod you have , that the first question?
02-27-2011, 03:42 AM   #13
QuoteOriginally posted by bobmaxja Quote
velbon cx 444
02-27-2011, 10:27 AM   #14
jatrax's Avatar
velbon cx 444
I don't think that tripod is rated for anything as heavy as the k-5. You don't say what lens you are using but that will also add weight to the total that has to be supported. Generally this type of tripod is fine for point & shoot cameras but is not going to be rigid enough for a dslr. You could try dampening the vibration by hanging a bag of sand under it.
Good tripods go for $200 - $400. I started out with one that was just to light for the job and it just leads to frustration. Finally got a ancient heavy beast at a garage sale for $15. It doesn't have all the bells & whistles of a new one, but it doesn't move either.
02-27-2011, 10:31 AM   #15
wlachan's Avatar
Hard to believe but I once had a Slik lightweight tripod which produced blurrier results than handholding. There was no SR back then.
camera, pentax help, photography, shutter
New Pentax KX, problem with double shutter movement leading to underexposure Tricerator Pentax DSLR Discussion 21 10-30-2011 09:01 PM
SR And Shaking Shub Troubleshooting and Beginner Help 4 03-21-2010 04:10 PM
Shaking lenses LeDave Pentax SLR Lens Discussion 26 11-14-2009 03:23 AM
Strange shaking JFMichaud Pentax DSLR Discussion 3 11-13-2008 04:13 PM
Freezing movement with shutter speed regken Photographic Technique 16 11-28-2007 03:01 PM
All times are GMT -7. The time now is 02:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
