Originally posted by zedex99 It appears that Pentax makerware precludes easy reading of the shutter count. That's pretty much what the forum at imatch said. If the shutter count rolls over at 10,000 then the reading of 888 could be 888; 10888; 20888 and etc. so in effect the shutter count is useless as the shutter should go 100,000 actuations before replacement. Right?
As deejjjaaaa said, you seem to be confusing shutter count and image name. THEY ARE TWO COMPLETELY DIFFERENT THINGS.
The image file name begins at IMGP0001.jpg and continues until it reaches IMGP9999.jpg, at which point it rolls over to IMGP0001.jpg again. However, the filename can be changed or reset at will. Put a memory card with a filename that is NOT the next one in sequence and your camera will pick that name up and begin sequential numbering from that point on.
The shutter count is an internal counter that is not accessable from the menu of your camera. There is absolutely no way for you to reset this internal counter, either deliberately or accidentally. It is recorded in the EXIF data of each image, along with a lot of other information, such as shutter speed, aperture, time, date, ISO setting, etc. The EXIF data can be viewed with several different programs, such as PhotoME, Exiftools or Opanda. Many photo editting software will display some or all of the EXIF data, as well.
To repeat, the image file name is ABSOLUTELY NOT TIED TO THE SHUTTER COUNT. AS I said, the image name automatically resets after 9999 and you can reset it at any time you want. The shutter count never, ever, ever, ever, ever resets.
Your statement above is backwards. The image name is useless for deteriming the "mileage" on your camera. The shutter count is absolutely reliable. Its sort of like the difference between the odometer (shutter count) and the trip odometer (image file name) on your car. The odometer is not resetable, while the trip odo is.
And, BTW, this naming convention is not of Pentax' invention. It is some sort of industry standard.
