Originally posted by Chaos_Realm Ie I press the shutter release..... Nothing.
It tends to do this when i shoot in low light.
Hi Scott,
The problem is likely to be the auto focus that is not able to catch focus as the others explained.
The main symptom to look for is called "focus hunting", the lens is constantly moving back and forward trying to find a focus lock.
Does that happen when you experience this problem?
The AF mechanism requires a contrast change at the focus point in use, this means that the camera cannot lock focus when there is no contrast. Not even when the light is great.
For instance, if you'd try to make a photo of a white wall, Auto Focus will fail.
Also, in low light, it is much harder for the AF mechnism to find contrast, there is simply less light to work with.
Your K-7 is equiped with an AF assist light. A sort of green light that should be turned on by the camera in very low light.
Can you see that happen? If not, it might be turned of in the menu.
Turn it on, it does help a lot in low light situations.
Success, Bert
