03-03-2011, 06:14 AM   #1
mblanc's Avatar
Can You Select MANUAL Focus Point on Kx?
Hi,
I almost always use manual focus, but I like having the focus indicator light/beep also. My question is - does changing the autofocus point from Spot to Select, or Autofocus 5 or Autofocus 11 change the area used to determine in/out of focus for the indicator? Or, does it only determine the area used for autofocus? Thanks.
03-03-2011, 07:10 AM   #2
boriscleto's Avatar
The autofocus points are used in MF mode but only by DA, DA L, D FA, FA J, FA or F lenses. Non-AF lenses default to center spot.
03-03-2011, 07:26 AM   #3
jeffshaddix's Avatar
QuoteOriginally posted by boriscleto Quote
Yeah it's quite sad, I don't see why this needs to be the case.
I use mostly KA mount lenses, so if I need focus confirmation I have to focus in the center and recompose, but with shallow DOF the distance to the object changes enough with recomposure that exact focus is lost. I've circumvented the problem a bit by getting a Ec-A focusing screen that uses ground glass so it's easier to focus with my eye. I'd recommend either getting good determining focus without the confirmation light, or using live view for precise focus (not always practical).
autofocus, camera, focus, indicator, pentax help, photography
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
K-5 Select Af point in live view telfish Pentax K-5 5 10-21-2010 11:38 AM
Manual Focus and Link AF Point yusuf Pentax DSLR Discussion 5 08-24-2010 11:56 AM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
All times are GMT -7. The time now is 02:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
