03-05-2011, 12:38 AM   #1
mcgphoto's Avatar
Numbers stamped on the Takumar lenses
Hi newbee here. please could someone inform me what the no means which is stamped on the rear of the am lever on the taks.
Thanks
03-05-2011, 01:26 AM   #2
They're aperture numbers: http://en.wikipedia.org/wiki/Aperture
A smaller number means that there's a bigger hole and thus more light passes through the lens. Larger numbers mean the opposite.
Then the number is small, the depth of field is small as well- i.e. not as much is sharp beyond the focal point as at larger apertures, and vice-versa for large numbers.
Here's an article with more on DOF and aperture use: https://www.pentaxforums.com/forums/photography-articles/126203-stops-shutter...nsitivity.html
03-05-2011, 01:45 AM   #3
mcgphoto's Avatar
Hi yes i understand those numbers but on the back of the auto and manual lever on the 50-55 taks is a no that is stamped that's the one i would like to know what it means
03-05-2011, 02:00 AM   #4
Are you talking about a serial number?
Give a few examples and that may help people help you.
03-05-2011, 02:22 AM   #5
mcgphoto's Avatar
Okay sorry the serial no on the am lever not the serial on the front of the lens. ill post a pic when i get home for clarification thanks.
03-05-2011, 02:25 AM   #6
Steinback's Avatar
The number on the auto/manual switch is the part number. Sometimes there will be two or three generations of a Takumar lens and the part number will change with each generation. With other lenses the part number remains the same through the entire production run. As an example, my SMC 135 f/3.5 is designated 43542, with a serial number in the 5.9 million range.
03-05-2011, 05:43 AM   #7
mcgphoto's Avatar
Yip that's the one thanks Steinback.
Has any one used the chipped adapters on the mf taks and how do you find them to work.
03-05-2011, 05:50 AM   #8
Sorry, but what's a chipped adapter ?
03-05-2011, 07:10 AM   #9
mcgphoto's Avatar
Its a m42-manual focus adapter with focus confirmation for use on theTakumar lenses
03-05-2011, 08:17 AM   #10
ChipB's Avatar
QuoteOriginally posted by mcgphoto Quote
Never seen one - but since most (if not all) of the Pentax DSLRs have focus confirmation in the viewfinder why would one be necessary??
03-05-2011, 08:40 AM   #11
boriscleto's Avatar
"Chipped Adapter" that's a new one to me. Focus confirmation does not require a chip to function. All that is necessary is the proper pin to be grounded. Some M42 lenses are large enough to ground the pin themselves. A Super Tak 50 is not wide enough. In this case you need to ground the pin with some foil tape.
Not all Taks have a number on the A/M switch. I have an 8-element Super Tak that does not. A 7-element Super Tak that does. An Auto-Tak 55 that doesn't and a SMC Tak 55 that does.
03-05-2011, 11:33 AM   #12
mcgphoto's Avatar
Okay its the m42 adapter one uses on m/f lenses for eg a canon 40d it fools the camera into thinking there's a normal lens on and your focus light will come on instead of trying to get manual focus through your eye piece.
03-05-2011, 11:43 AM   #13
boriscleto's Avatar
Ah, you didn't specify that you were one of those who drive up the prices of our Taks
03-05-2011, 12:15 PM   #14
mcgphoto's Avatar
What you mean over here they range from 10 pounds for a 55 1.8 in good condition to a 200 f4 for 40-50 pounds just have to look.
I bought my spotmatic with a super tak 50 1.4 for 50 pounds in excellent condition.
03-05-2011, 12:27 PM   #15
ChipB's Avatar
Be pretty tough using that Canon adapter on a Pentax DSLR.
K-x with old Super Takumar lenses? Stelaine Pentax DSLR Discussion 13 07-16-2011 10:38 PM
Takumar Lenses RielTime Pentax SLR Lens Discussion 6 02-25-2009 10:22 AM
For Sale - Sold: Super Macro Takumar 50mm, Super Takumar 200mm, F 35-80mm Lenses Nick Siebers Sold Items 4 02-01-2009 08:56 PM
Takumar Serial numbers pdxbmw Pentax SLR Lens Discussion 3 10-29-2008 02:02 PM
Lenses and what do the numbers mean? Leana Photographic Technique 31 01-29-2008 08:30 PM
All times are GMT -7. The time now is 07:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
