03-05-2011, 02:48 PM   #1
applejax's Avatar
Is my flash shot?
Decided to try playing with my AF540 on manual as I've been unsatisfied with its results recently. I had even more trouble and some odd behavior.
I turned the light off so it was quite dim, but I was inside with some small windows, so some light was coming in. Definitely not a lot, though. I randomly decided to shoot some chachkis on a shelf about four feet away.
I didn't take detailed notes for patterns, but often the flash didn't fire at all. I tried the flash on P-TTL, manual; tried the camera between green mode, aperture, and manual modes. Often, the flash didn't even fire. Every shot, though, was totally black. When I put the flash in manual, it would get stuck and nothing on the display would change. Even when I turned the flash off, the display on the LCD would remain.
Any ideas?
Thanks;
David
03-05-2011, 03:50 PM   #2
The first thing I would blame would be the batteries. Second would be that the flash may not be fully or properly seated on the shoe. Did you try Wireless by any chance?
More details would help. Perhaps a photo (even if black) with exif in tact. Lens used, Camera used, etc.
03-05-2011, 04:34 PM   #3
Ash
Community Manager
Ash's Avatar
First thought is mounting problem as Jeff stated.
The 540 is particular about how it is seated on the hotshoe mount, so push the hotshoe in firmly and try again in P-TTL mode and see if it works. If you've had your hotshoe pin removed for the stuck pin problem this issue will be a recurring theme.
But the other bizarre behaviour of the flash mentioned in the latter part of your thread is hard to figure out. Check the batteries and their contacts. Then after all efforts have been exhausted, you may need to look at repair...
03-05-2011, 10:12 PM   #4
applejax's Avatar
Thanks, guys. Had an event tonight which was the catalyst for my experimentation. Resorted to the built-in flash.
While the batteries should have been fine, I did pop fresh ones in with no change. I've also noticed that the lever goes awfully far to the right when I try to seat the flash.
I don't have much hopes, but I'll post some shots (even black) along with better details tomorrow.
Thanks;
David
display, fire, flash, light, pentax help
Nature "Did you ever use your pop-up flash for a wild bird shot?" Rense Post Your Photos! 5 07-21-2010 02:20 AM
Shot random people outside with a flash? Zakovva Photographic Technique 21 09-02-2009 02:25 PM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
Maria, Portrait... beautiful although shot with builtin flash Alcazar Post Your Photos! 0 04-20-2008 04:15 PM
2 flash product shot Tyler Post Your Photos! 6 03-10-2008 12:20 PM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
