03-07-2011, 12:31 PM   #1
Pentax S-M-C Takumar 135mm auto/ manual
I just purchased my first Pentax lens for use on my m4/3s camera. it's a Pentax Super Multi Coated Takumar 135 2.5 M42. It has an switch on the base marked auto and I think "man" for manual. The switch as I received the lens is in the auto position. I tried gently to set it to the manual position but it doesn't want to move. I don't have the instructions so I am guessing I don't know what I am doing. Can someone help me with this?
03-07-2011, 01:01 PM   #2
Just1MoreDave's Avatar
Your lens mount looks nearly identical to this one:
All the way on the left of that photo, partially hidden, is a really small pin. The pin is designed to lock the Auto/Man switch in Auto. (They had a good reason which is not relevant on a DSLR.) Make sure you've got your pins right - not the chrome pin at the top of the photo, not the square lug either. If you hold the pin in with a thumbnail, the switch moves freely. Putting the original or similar cap on the lens also holds the pin in, or (probably) putting the adapter on the lens (I don't know about the m4/3 adapters). Once the switch is in Man, you can leave it there.
I apologize for not showing the tiny pin better in this photo.
03-07-2011, 01:16 PM   #3
boriscleto's Avatar
Here's a better shot of the pin.
03-07-2011, 01:21 PM   #4
Lowell Goudge's Avatar
the little pin needs to be pressed in, to get the A/M switch to move,
either screw on the lens cap (rear) or mount it on your camera.
this threw me for a loop too, but the pin is there for a purpose, to leave lens in the correct mode on the Spotmatic F and ES II which allow for full aperture metering. Note the additional aperture coupling lever on the lens (just like the K mounts)
03-07-2011, 01:27 PM   #5
QuoteOriginally posted by boriscleto Quote
SMC Takumar 1:1.8/55?
03-07-2011, 01:47 PM   #6
boriscleto's Avatar
QuoteOriginally posted by Just1MoreDave Quote
Yep.
03-07-2011, 05:11 PM   #7
Thank you to everyone for educating this newbie; I figured it was probably operator error.
03-07-2011, 05:14 PM   #8
Thank you all for educating this newbie. I was betting on operator error. I am really impressed with the build quality of this lens.
03-07-2011, 08:32 PM   #9
I know the feeling well. Get the box, take out the old newspaper, tear off the bubble wrap, finally extract the lens, look in one end, look in the other, then ten seconds later, crap, it's broken! Did I do that? Was it like that before? If something like this hasn't happened to you, you haven't bought enough stuff from eBay.
auto, camera, lens, pentax, pentax help, pentax s-m-c takumar, photography, position, s-m-c takumar 135mm, switch, takumar
For Sale - Sold: Pentax-M 50mm f1.7, Takumar Bayonet 135mm f2.5, ME Super + manual (CONUS) acrollet Sold Items 2 11-06-2010 03:10 PM
SMC Takumar 85mm 1.8 Auto/Manual Switch Jammed Irishwiseguy Pentax SLR Lens Discussion 12 06-29-2010 11:36 AM
135mm Takumar manual lens ChrisC Pentax SLR Lens Discussion 6 07-06-2008 01:44 AM
All times are GMT -7. The time now is 06:48 PM. | See also: NikonForums.com, part of our network of photo forums!
