11-06-2011, 10:10 PM   #31
I don't know if you have solved that problem of taking the BOWER BODY MOUNT from your lens. If not, than its very simple. There is a small screw on that adapter, remove it, take a safety pin, put it inside that hole, there will be like a small golden color spring in there, move that to the opposite direction and remove the adapter from the lens and VIOLA..... problem solved.
Cheers
11-29-2011, 05:16 AM   #32
Migno's Avatar
QuoteOriginally posted by JeffJS Quote
If you're trying to remove the adapter from the lens, use a K mount rear cap so you can get hold of it. I've removed adapters that were Glued on this way.
Great idea, thanks
adapter, lenses, m42, m42 adapter, pentax help
m42 to PK adapter stuck irakperez Pentax SLR Lens Discussion 18 11-08-2010 05:01 PM
Help! m42 adapter stuck on camera ADHWJC Pentax SLR Lens Discussion 8 09-23-2010 12:23 PM
How to remove a stuck M42 - K-mount adapter Tim_R Pentax SLR Lens Discussion 5 09-07-2010 04:11 PM
Boyer m42 adapter stuck in camera? jsherman999 Pentax SLR Lens Discussion 12 02-08-2008 05:54 AM
HELP! M42 adapter stuck on lens! figmental1978 Pentax Camera and Field Accessories 2 12-27-2007 05:44 AM
All times are GMT -7. The time now is 07:52 AM. | See also: NikonForums.com, part of our network of photo forums!
