Originally posted by sterretje You obviously don't believe me
If you start modding the fotodiox, there is a chance that you will never get it out of your camera.
I believe you.
I'm trying to learn why it won't work. If I have that answer, then there might be a solution.
I have 3 choices.
1. Try to mod the Fotodiox because it does screw on onto my 135mm. (The original Pentax doesn't & I don't want to risk stripping the threads on the adapter or maybe even more on the 135mm)
2. Leave it the way it is and not have infinity focus.
3. Try to have the threads re-threaded.
I always try to see what answers might be out there.
After your post, there were some good ideas that I might try myself. Now that I see what needs to be done, I will try and see if I can do it and maybe even find a way to build a better mouse trap in the process.
---------- Post added 03-18-11 at 11:15 AM ----------
Originally posted by excanonfd It is precisely because of the wide flange - the wide flange adds about 1mm to the lens mount, which makes the lens go beyond the registration distance of 45.46mm by just slightly under 1mm.
Thanks,
I was thinking about cutting off the flange. So that it's more like the Original Pentax adapter which fits into the body. I measured the two adapters, and once the outer ring is removed it will fit just like the original.
(Click to see larger image)
However, there is no release lever. That's where there could be a problem. If the lens is tighten too far, when you remove the lens, the adapter might stay inside of the body of the camera.
However, there are a few work a rounds that problem as well.
It looks like I'm going to make this a permanent adapter on this lens. So, once it works, I'll drill two pin size holes thru the adapter into the lens. Then, make sure they are flush, maybe glue them in and it's just like a K mount.
Unless I'm really missing something, I think it might work.
Okay, I'm ready to hear why this might or might not work..
---------- Post added 03-18-11 at 04:01 PM ----------
It's Working!
But not the way I planned. I took it over to this guys home-workshop to get his input. I told him what I wanted to do.
He gave me a weird look and than took the Original Pentax, the fotodiox, and the lens. While I was talking to his wife, he fixed it. Without even having to re-thread the lens. Took him less then 5 mins with a razor thin file to clean up the threads.
He's said when he has time, he'll work on my idea to see if it might work.
I'll get back to you on it.
Here's a few pics from it. It's raining like a dog here & I had the ISO up to 400 by mistake.
I picked this up yesterday-Tele-Takumar 300mm f/6.3
Now, I can hardly wait for a nice break in the weather next week to take it out and see what it can do..
---------- Post added 03-18-11 at 07:56 PM ----------
Originally posted by chedoy As for a flanged adapter from fotodiox, wasn't there a disclaimer that they cannot focus to infinity?
The description stated that the adapter did focus to infinity. After reading your question I went back to check to make sure as I had not read it when I ordered it. I called my friend and put a stop to him working on it, and then packed them both up and sent them back to Fotodiox for a full refund. Glad I didn't cut them up..
