03-08-2011, 04:25 AM   #1
Exposure time and camera
Do exposure times vary according to camera make? Using my pentax k2000, using f2 lens at f2, I always get exposure time greater than 1 sec for indoor shots with ISO < =200.Even with ISO bumped to 800, I can never go over 1/20. Wonder if the GXR is a great low light performer. Eg:-
Exif | VenusFort | Flickr - Photo Sharing!
So, using the same lens at the same aperture,same light conditions, do exposure time vary for different cameras?
03-08-2011, 05:43 AM   #2
Lowell Goudge's Avatar
in principle, ISO 200 is the same on every camera, but there has been some debate on camera makers deliberately mis calibrating things.
for lenses, F2 is a mechanical property of the lens, specifically the focal length divided by the opening diameter . Individual lenses may have different light lossses so exposure can vary from lens type to lens type.
your issue is shooting at IS0 200,. if you can't get exposure at ISO 200 no camera will, you need either to raise the ISO or add external light.
when they talk about low light performance they are talking about the difference in image quality at high ISO from one camera to another.
03-08-2011, 05:47 AM   #3
They shouldn't. You do get slight variations between lenses as they transmit slightly different amounts of light but I say again, these are slight variations - for example the same ISO and f-stop in identical conditions might give 1/30th on one setup and 1/25th on another.
You weren't there with your camera when they took the shots, so you don't have a direct comparison. I suspect the location had a lot more light than the average indoor setting.
03-08-2011, 08:34 AM   #4
QuoteOriginally posted by cats_five Quote
I have an old rikenon 135F2.8 which begs to differ. it is a full stop slower at any aperture.
there are also many "anicdotal" comments about large differences between DA or similar technology lenses even posted in the forum.
Not saying they are all right/correct in the post, but the issue is often commented or reported on.
At one time, there were lenses calibrated in T stops, this went away not so much because lenses got better (they did but that was coincidence) but because metering, and later flash metering were done through the lens, so knowing the true transmission factor became less important.
to get back to the OP's post, I think the final question is, YES. Same light Same lens, same settings, exposure does change because of what I mentioned earlier, each camera maker "cheats" a little on declared ISO.
camera, exif, exposure, exposure time, f2, flickr, iso, pentax help, photo, photography, time
how to bracket exposure time? Urmas R. Pentax DSLR Discussion 4 02-01-2010 07:31 AM
Exposure Time fusionimaging Troubleshooting and Beginner Help 6 11-29-2009 01:31 PM
Camera Exposure Compensation with Flash With camera in Manual Mode jrforman Flashes, Lighting, and Studio 0 09-11-2009 10:03 AM
Long time exposure must use NR? yipchunyu Pentax DSLR Discussion 21 06-21-2009 05:08 PM
Trouble with Exposure Time jcleary47 Photographic Technique 7 06-17-2008 04:24 AM
All times are GMT -7. The time now is 12:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
