Originally posted by NRV Shooter With the EOS to M42 adapter installed on the camera, could not an Adaptall 2 lens with an M42 adapter then be mounted to the camera and function with manual settings of both shutter speed and aperature required? Would the Av setting on the camera work?
I saw this thread and have the same question about finding a way to use Adaptall 2 lenses on a Canon Elan II EOS.
Adaptall/EOS adapters are available, but would work the same as Adaptall->M42->EOS
Here's a list from a seller's posting:
AF Confirm Tamron Adaptall II Lens to Canon EOS Adapter - eBay (item 200539819037 end time Apr-04-11 02:17:10 PDT)
FEATURES:
*P (program)----identical to Av mode.
*Tv (flash priority)----does not work.
*Av (diaphragm priority)----works as usual.
*M (manual)----aperture and flash are changed. Inaccuracy of exposure defining is indicated by expo-correction.
*EXIF is fixed 50mm f1.4.
