03-12-2011, 01:17 AM   #1
Stuck zoom lens
I have a K-x with a DAL 18-55 AL lens. The zoom operation has become limited to between the 18-24 mm marks.
I last used the camera before the problem arose to photo some boat repairs using 2 part epoxy resin. I suspect that the prolem is related to getting some of the resin/glue on the lens grip. There is small amount of glue on the grip ring, but I cannot find any glue on any parts that move against each other. Withing that range the zoom moves freely.
The camera now also appears to have issues autofocusing. It will no longer focus on objects close to the camera.
Any suggestions? Thanks
Vincent
03-12-2011, 03:45 AM   #2
Welcome to the forum.
The good news is, 24mm is about where that lens is the sharpest.
Is that the only lens you have? You state your camera is having difficulty with AF and I'm wondering if it is just that lens or if it is the camera? If it is the only lens, can you Manually focus it?
03-12-2011, 06:03 AM   #3
Thanks for the welcome and the advice/question.
I shifted to Manual and attempted to focus and found that a bit of glue had gotten between the manual focus and zoom rings. A little forceful twisting freed things up.
This is my first digital SLR. I used film SLR's for years, shifted to digital out of convenience and assumed a digital SLR would not significantly improve picture qualtiy. I was wrong and am well pleased with the K-x.
Thinking the damage might be permanent, I reviewed the forum lens evaluation and found a DA 18-55 II, on Amazon for $60 and orderd that. Considering my picture taking enviroment of boats and boat repair this is probably a good thing.
Regards,
Vincent
03-12-2011, 06:35 AM   #4
I think it is not related to the epoxy resin. From my experience with boat resins (or just plain epoxy resin) if it is going to get somewhere to stop a motion, it is going to completely stop that motion.
camera, glue, grip, lens, pentax help
DA* 16-50 stuck - won't zoom or focus amoringello Pentax SLR Lens Discussion 23 12-13-2016 11:05 AM
My CPC Auto Zoom lens got stuck on my K20D mulberrybean Pentax SLR Lens Discussion 6 10-01-2014 01:37 PM
AF-540FGZ zoom stuck at 16mm?? joeyc Pentax Camera and Field Accessories 9 04-03-2012 05:08 PM
AF-360FGZ stuck in manual zoom Scorg Pentax Camera and Field Accessories 3 11-15-2010 05:30 PM
Stuck zoom ring photogwannabe Pentax SLR Lens Discussion 5 06-08-2009 03:31 PM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, part of our network of photo forums!
