03-12-2011, 05:28 AM   #1
K10D with AF360FGZ
I am trying to get my AF360FGZ to fire off camera wirelessly using the built in flash as a trigger. First I updated the camera's firmware to version 1.3 and then followed the instructions with the flash. I have got as far as the part which says:
"While pressing the camera's flash function button, turn the select dial until WHS appears."
I know I am being a bit dim here, but I have 2 questions:
1) Which is the flash function button on the K10D - I can only find the button which pops up the flash
2) I assume the 'select dial' is the dial on the flash, not the camera - am I correct?
Can anyone point me in the right direction?
Bill
03-12-2011, 06:06 AM   #2
With the camera on, press the Fn button on the rear panel. using the 4 way controller, select the flash, select wireless on the far right.
On the flash..... the on/off switch has a position for wireless....first position IIRC.
03-12-2011, 06:31 AM   #3
You also have to make sure the 360 is set for Slave and be sure the flash and camera are on the same channel (usually channel 1). You can set the K10d flash, in the custom menu, to fire either as a Main flash or as a controller. In the latter case, it will only fire a short pre-exposure burst for P-TTL and I believe it will fire another one during the exposure. Also note that the slave (360) has to be somewhere within the line of sight of the K10d control flash. Finally, unless you are using another 360 as the master (or similar), there will be no HSS. 1/180 will be the limit.
03-12-2011, 09:57 AM   #4
Thank you, both. Works fine. First day on this site and I'm learning already!
Bill
af360fgz, button, camera, flash, function, k10d, pentax help
AF160FC + wireless AF360FGZ with K10D luakz Flashes, Lighting, and Studio 3 03-17-2010 06:27 AM
K10D and AF360FGZ Flash in Wireless CrazyNuts Pentax DSLR Discussion 8 12-26-2009 02:48 PM
K10d + af360fgz ndy4eva Pentax DSLR Discussion 4 08-26-2009 09:01 PM
Using AF360FGZ wirelessly with K10D Clem Nichols Flashes, Lighting, and Studio 0 02-02-2008 06:51 AM
AF360FGZ and K10D problem boxcam78 Pentax DSLR Discussion 1 11-03-2007 02:42 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
