03-13-2011, 05:02 PM   #1
K-7 and continuous focus
Hi.
Yesterday i made some shots of a person running towards me. I had problem getting focused as the person were coming nearer and nearer to me. In the beginning it was OK, but the camera got more and more problem to fokus the nearer the person came to me.
I tried out the focus switch at both AF.S and C. The camera was also set to take shots in series.
The manual do not mention much about this subject.
What coult Ive done wrong
I would be most grateful for helping advice
03-13-2011, 05:19 PM   #2
Make sure you point on something that's contrasty, and make sure there's a good deal of ambient light. The K-7's AF system isn't as good at continuous AF as the K-5, though, so some of the problems may be attributed to the body itself.
03-13-2011, 06:35 PM   #3
mysticcowboy's Avatar
Another point is that continuous autofocus has more problems with subjects coming straight at you than those moving at an angle. Also as subjects get closer a smaller mis-focus will have a more noticeable effect. The difference between 25 and 30 feet is a much smaller percentage than the difference between 10 and 15.
03-13-2011, 06:42 PM   #4
Ole
Ole's Avatar
You have to stick to AF.C for moving subjects.
As Adam said: Sufficient contrast and light is the key.
In AF.C and continuous shooting the camera will fire as fast as it can whether or not the subject is in focus.
The K-5 has an option where you can prevent the "misfires", in other words, the camera can be set to only shoot when the focus mechanism has caught up with the moving subject.
03-14-2011, 02:47 PM   #5
michael mckee: I guess this is what I experienced. The problem occured as the person came closer. At distance there was no problem.
Ole: I experied that the camera did not fire continously at AF.C, but halted as the focusing problem occured. I guess I need to test this a lot more the nearest days.
By the way: Nice pix in your gallery from my area in the Geiranger gallery
03-14-2011, 04:54 PM   #6
GoldenRGuy's Avatar
Were you using a fixed or zoom lens? I've been playing with this for months. (see my previous posts..)
Using a zoom, I've decided the best way to get proper focus with a zoom, is to anticipate the shot a bit, use AF.S 1/2 press, wait for the beep and pull the trigger.
You really have to play with it. I still get shots with my dog's face out of focus, but his chest is sharp
03-14-2011, 04:58 PM   #7
hcc
hcc's Avatar
I wonder if there is some misunderstanding on the expression 'fire continously'. It could be interpreted as continuous shooting (or burst mode), or continous focus (AF.C). Let me share my own experience with Hi continuous shooting and the K-7.
If you decide to shoot continously (Hi continuous shooting), my experience suggests that AF.S and MF are the best:
* in AF.S, try to focus on a point in the middle of the path of the person running towards you.
* MF is possibly better (especially with a true MF lens with a nice focus ring), as you can refocus manually during the run.
With AF.C, the burst rate (5.2 pfs) does slow down as the camera try to re-focus. If you do not care about the burst rate, then AF.C is ok.
I add that I like to use the highest burst rate (5.2 fps) and I switch all all in-camera PP and avoid AF.C to maintain the fast burst rate.
Hope that the comments will help.
03-14-2011, 06:50 PM   #8
Ole
Ole's Avatar
QuoteOriginally posted by pentax611 Quote
Thanks! We have vacationed in Norway the past several years, we love it, it is a breathtaking country in particular for someone who grew up in Denmark where the highest point is less than 200m above sea level!
03-16-2011, 02:24 PM   #9
All of you:
OK, thanks a lot for good hints. As a "superamateur" I need to practice a lot and Im sure your comments will be of great help for me!
Ole:
I`m proud to tell that Ive "climbed" that mountain in Denmark ;-)
camera, focus, pentax help, person, photography, shots
Continuous Lighting-I'm trying it philbaum Photographic Technique 18 10-21-2010 10:57 AM
Continuous shooting fekish Pentax DSLR Discussion 8 09-24-2010 05:58 AM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
Continuous focus result... beaumont Post Your Photos! 3 07-23-2009 10:53 AM
Continuous auto-focus with K10D Clem Nichols Photographic Technique 14 02-06-2009 05:37 PM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
