03-13-2011, 07:16 PM   #1
liukaitc's Avatar
What auto flash means?
What auto flash means? I heared some flash does not do auto flash..what this means.
03-13-2011, 07:24 PM   #2
SpecialK's Avatar
The flash has a sensor that determines the correct exposure. They normally also have a manual mode that puts out full power (some have fractional power settings), and you determine the aperture to use based on the cameras-subject distance.
03-13-2011, 08:30 PM   #3
ScooterMaxi Jim's Avatar
Auto flash
Modern p-ttl flash uses a short pre-flash that measures the light within the camera, and then provides the proper reading through the lens (as such, ttl). Most often this works well, but it can on occasion result in a blink or droopy eyes, or if the flash isn't seated quite right you get a wrong exposure (due to smaller extra connections).
Auto flash measures the light with a sensor on the flash. Although slightly less precise, it can be a bit more dependable overall when comparing single flash situations.
If you want to look at a good guide to Pentax p-TTL flashes - that also mentions auto mode units, check out Matt Miller's site:
Other Flash Modes - Pentax P-TTL Flash Comparison
It is worth it - in my opinion - to pay a bit extra for auto to go with pTTL (or go the cheap route and just get a non-TTL flash). Auto is a lot easier and more precise than manual output using ratios.
JNR
auto, auto flash, camera, flash, pentax help, photography
can anyone explain what it means when a camera is goosed? naughty.smurf Photographic Technique 8 09-07-2010 10:16 PM
Spring in the Netherlands means tulips! newmikey Post Your Photos! 6 04-21-2009 11:00 AM
Varifocal means? FHPhotographer Pentax SLR Lens Discussion 22 09-22-2008 07:06 AM
Green Means Go: Some GIMP Silliness Mike Cash Post Your Photos! 1 12-13-2007 08:53 AM
Snow and ice means B&W to me (mostly anyway) NaClH2O Post Your Photos! 11 01-31-2007 07:06 PM
All times are GMT -7. The time now is 07:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
