Originally posted by HGMonaro yeah but... I want the off camera flash to be the main/only light source. Correct me if I'm wrong, but I thought it was capable of this? IF so, what settings should I have (on camera and flash)
The remote (slave) flash can be the main source, but it can NOT be the only source.
In wireless flash, the built-in flash (or the flash attached to the camera) ALWAYS fires during exposure. If you set it as the control, the strobe will be weaker than when it is set as the master. But there is no way to prevent the control/master flash from firing.
This applies not only to Pentax p-TTL, but also to all flash techniques that use a preflash strobe.
The only way to NOT have the built-in flash to fire is to use RF remote, or a long flash extension cord.
