Originally posted by sifun Exposure is too bright- either direct or bounce, the subject is over-exposed.
the subject is half a metre away- example F4, 1/180, ISO AUTO
I'll try the 2 sec timer mode to see if theres a pre flash. I should be able to see it 1/50 should be slow enough to see it.
1/2 meter away is way way too close. You need to bounce it behind you if your camera is that close to the subject, or get it off camera.
My k-x is very very consistant using pTTL, I find it excellent, your K-7 should be the same.
What mode are you shooting in? If it's indoor you should be in manual mode on the camera and pTTL on the flash, then control your flash exposure using the FEC on your flash unit. If you are using the flash indoor in Av mode on camera and pTTL on the flash, then you absolutely need to change that and shoot manual mode on the camera, in Av mode the flash acts as fill flash only, and the camera exposes for ambient only.
