03-17-2011, 02:59 PM   #1
slip's Avatar
how do you know?
how do you know if your shake reduction is working?
I have a K10D and when I compare shots with or without it on, they look for the most part the same. handshake light does come on.
any thoughts appreciated
randy
03-17-2011, 04:19 PM   #2
Lowell Goudge's Avatar
Take a 50mm lens and shoot
With it on and off at 1/10 of a second shutter. You'll know the
03-17-2011, 04:21 PM   #3
SpecialK's Avatar
It will be the most noticeable at low shutter speeds like 1/4 - 1/10 as Lowell mentioned. At 1/500th it still works but there is far less movement.
03-17-2011, 06:24 PM   #4
If there is any movement at all, there is the same amount regardless of shutter speed (within reason). You're just recording less of it. People managed to take clear sharp photos long before SR (but I wouldn't want to be without it now as I've grown to depend on it somewhat).
03-17-2011, 07:21 PM   #5
SpecialK's Avatar
QuoteOriginally posted by JeffJS Quote
How does the camera move the same distance in 1/500 as in 1/10?
03-17-2011, 07:51 PM   #6
It doesn't. That's my point. If the camera is moving however, it is still moving at the same rate at 1/500 as it is 1/10. Both times are faster than most will notice Anything happening. You're just recording a smaller slice of it.
pentax help
All times are GMT -7. The time now is 12:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
