03-19-2011, 07:19 AM   #1
Thin white vertical lines in photos
Hi All-
I recently had some service work on my Pentax K7 where they replaced the PCB and updated the firmware. I have started shooting again and am now seeing thin white vertical lines in all of my photos. It is most noticeable in darker portions of the images but it is visible even in light sections too. Any ideas as to what might be causing this and how to correct it? Is this an issue with the camera settings or a default in the firmware?
Many thanks for any advice you can offer!
03-19-2011, 07:26 AM   #2
SpecialK's Avatar
I do not know the specific cause of the problem, sorry, but there is no setting in the camera to cause vertical lines. I'm guessing it is hardware.
I would return it to service.
03-19-2011, 07:53 AM   #3
ducdao's Avatar
QuoteOriginally posted by gharber Quote
Hi All-
I recently had some service work on my Pentax K7 where they replaced the PCB and updated the firmware. I have started shooting again and am now seeing thin white vertical lines in all if my photos. It is most noticeable in darker portions of the images but it is visible even in light sections too. Any ideas as to what might be causing this and how to correct it? Is this an issue with the camera settings or a default in the firmware?
Can you post a picture that has that problem? That would certainly help the diagnosis.
03-19-2011, 08:34 AM   #4
jmschrei's Avatar
It sound like the kind of banding I've seen when outdoors under very cold conditions. In that situation I put it down to the battery slowing as it gets colder. (I could be wrong of course.) If you are sure your battery is healthy and fully charged and this appears on every shot I would return the camera for further servicing.
-Joe
03-19-2011, 03:07 PM   #5
I'm completely new to the forum and am unfamiliar with posting images to the site, so I posted some shots to my Flickr page: Flickr: gharber's Photostream The first three photos (caracara, salvia and alligator) show the lines in the darker segments of the images. If you need to enlarge them to see the lines click the ACTIONS icon at the top left corner of the image and then select View All Sizes. Many thanks for your feedback thus far.
03-19-2011, 03:29 PM   #6
Definitely back to service, unfortunately. Photos should not come out of the camera in that manner.
03-20-2011, 12:13 AM   #7
ducdao's Avatar
QuoteOriginally posted by pxpaulx Quote
+1 something is really wrong with it. You should return it ASAP.
firmware, lines, pentax help, photos
K-7 -> Vertical banding in low light black and white video RonHendriks1966 Pentax DSLR Discussion 14 09-17-2010 11:41 PM
K1000 - Thick black vertical lines on my photos skid2964 Pentax Film SLR Discussion 11 11-27-2009 12:27 PM
Histogram Vertical Lines Significance fwcetus Pentax DSLR Discussion 7 04-02-2009 01:46 PM
Straightening vertical lines question... sawtooth235 Photo Critique 14 02-08-2009 04:20 PM
Vertical lines still an issue Christian Pentax DSLR Discussion 10 05-21-2007 07:08 AM
All times are GMT -7. The time now is 03:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
