Yup, it makes no difference what the exposure settings are, I tested outside in full sunlight on all modes even manual and AUTO with different settings....all with the same results.
I even reset the camera to default.
Checked the Exif with PhotoMe, all of the black images registered all the camera settings in the EXIF, regardless of the lens used. Nothing but black. Even if you push the levels up to see if there is any hint of an image, there is nothing.
Camera worked one moment - the next; everything worked except that the sensor transferred only black to the SD card.
The fact that it transferred image info to the SD card, means its transferring the camera data, so the SD is not faulty.
But all that it transfers is black with different exposure settings etc in the EXIF.
And yes the lens caps were off.
It was impossible to buy a Pentax body separately here, the retailers were only interested in selling me another body AND more lenses. Which to me is unacceptable.
After that, I regretfully have decided to move over to Canon after years of using Pentax since 35mm days.
