03-19-2011, 10:52 AM   #1
di-pod?
i am wondering if anyone makes a dipod? i know of monopods and tripods, but i would think a dipod together with the photographer would be a good tripod ?
thanks
03-19-2011, 12:13 PM   #2
RXrenesis8's Avatar
Try hunting sticks. It sounds like that's what you're after.
03-19-2011, 01:05 PM   #3
thanks, i'll look up hunting sticks.
03-19-2011, 01:20 PM   #4
QuoteOriginally posted by dh4412 Quote
Also called "Shooting Sticks"
03-19-2011, 04:37 PM   #5
Ex Finn.'s Avatar
Is that not also called a bi-pod?.
I will find something on you-tube and post a link.
Perfect.
03-19-2011, 05:01 PM   #6
this is basically what i'm looking for, now, i need a bean bag tripod head, or something to adapt this to a camera?
thanks
03-19-2011, 05:21 PM   #7
mickeyobe's Avatar
dh4412,
What happens to stability when you swivel the camera 90 so that the two legs line up one behind the other?
Mickey
03-19-2011, 07:09 PM   #8
i was thinking i would pick up both legs and re-plant them when i wanted to move a lot; but it is a good point. maybe a monopod would work just as well, but with a swivel type head of some kind? just i think taking a tripod hiking is probably something i won't do. a monopod with a decent sized beanbag top that one could sit the camera on but not have to screw the camera into, do you know what i mean?
thanks
03-19-2011, 07:15 PM   #9
RXrenesis8's Avatar
You mean like a monopod with a ball head and a quick release plate?
Amazon.com: National Geographic NGTM1 Tundra Monopod with Head and Quick Release Plate 785PL (Gray): Camera & Photo
03-19-2011, 08:16 PM   #10
yes, something like that national geographic monopod, but i seem to want to have the ability to put the camera on a bean bag instead of fixing it to the threaded screw, maybe though the quick release plate would be ok, just had the thought that with a beanbag head one could move the camera around easily , i don't know if it would work in practice though. thanks
03-19-2011, 08:44 PM   #11
Try the trek pod, camera attaches via a very strong magnet, there is a cupped screw head that screws into the tripod mount on the camera which fits snugly on a moly magnet attached to a ball head on the monopod. check it out I have the precursor to the trek pod II and I love it.
NaCl(one of my most used pieces of gear)H2O
03-19-2011, 11:54 PM   #12
this trek pod II looks pretty cool, that could work. thanks.
03-20-2011, 03:24 AM   #13
I found that a simple Y shaped yoke (like on a shooting stick) works well for me. I have also used a strong magnet - but did not have the magnet on an articulating head.
The lens barrel is rested in the Yoke. This allows quick up & down aiming of the camera so the monopod shaft need not be tilted.
I use the monopod mostly for long lens wildlife & sports photography. It helps stability, but maybe even more important, allows me to track a bird or goalie with a long lens for much longer than I can hand hold the camera.
Here's a summary photo of a monopod that breaks down into three segments short enough to stow in a small camera bag. It was built from the legs of a small tripod - shown on the left. I use one segment for tabletops, two for theater or when seated, and three when standing. The segments screw together with standard tripod threads so the camera can also be secured with the screw or a ball head can be added.
03-20-2011, 11:07 AM   #14
this is pretty interesting the way you made this out of a tripod, the yoke sorta solves the problem of having to screw the camera into the monopod or tripod, i like this.
thanks
03-20-2011, 11:32 AM   #15
thanks
As you seem interested here's how I assembled it. The mini-tripod and yoke (from a shooting stick) were both purchased at Walmart.
Shown above the monopod segments are a 1/4-20 tpi coupling nut and a 1/4-20 tpi hanger bolt (1/4"-20 threads per inch is the standard tripod mount thread specification) - standard hardware store items.
The coupling nuts were shoved into the bottoms of the individual tripod legs and glued in place with epoxy; The screw thread end of the hanger bolts were shoved into the tops of the tripod sections and epoxied in place.
With this arrangement as many monopod sections as desired can be securely screwed together and the yoke, camera, or tripod head mounted on top. As it turns out I only use the yoke.
I built this rather than simply use a shooting stick because I wanted to be able to store the thing in my camera bag. I'm physically limited & can't lug much.
my next project may be a stealth monopod made from a cane extensible to about 6' with a "Derby Head" for theater, museums etc.
Macro Seed Pod Re-Shoot? tessfully Photo Critique 8 02-09-2011 02:59 PM
Abstract Seed Pod Bob Harris Post Your Photos! 4 01-05-2011 05:43 PM
Macro Cactus Seed Pod Bob Harris Post Your Photos! 4 12-10-2010 11:18 PM
Nature Milkweed pod WPRESTO Post Your Photos! 3 10-14-2010 02:26 PM
GORILLA POD - who has one? Panache Pentax Camera and Field Accessories 9 12-29-2009 09:15 PM
All times are GMT -7. The time now is 10:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
