03-31-2011, 09:37 PM   #61
Chex's Avatar
I must say, I have shot a few jpegs and minor pp work tweaks are no problem. But if they are underexposed the jpeg can't handle the PP work. This weekend I hope to get a few hours to go out shooting and I intend to shoot RAW+ so I can see what I can do with both.
03-31-2011, 11:06 PM   #62
Just1MoreDave's Avatar
Here is my argument for RAW:
It's taken with an IR filter, so the information in each color channel varies wildly. It really helps to have the maximum information because IR colors aren't real anyway. These images need a lot of processing. I also revisited this 4 year old image because I got new noise reduction software that works at the RAW file stage.
I think I learned something from processing every photo. I like the information I get from Adobe Camera RAW.
Most of my images would be fine in JPG, but RAW doesn't seem that much extra trouble at my current photo rate.
03-31-2011, 11:53 PM   #63
jsherman999's Avatar
A quiz to pass the time!
The numbered images below are a mixture of raw & jpeg - Which are raw (DNG or NEF converted in Lightroom/ACR) and which are JPEG (with some minimal +sharpness in-camera and possibly slight PP in picasa) ?
1
2
3,4
5
6,7
8
9
10
04-01-2011, 12:35 AM   #64
Ash
Community Manager
Ash's Avatar
Jay, it'd be a guess with your work, knowing you expose your shots well...
And as a result, RAW vs. JPEG is much of a muchness with adequate exposures.
Even still, I shoot RAW.
04-01-2011, 12:56 AM   #65
Jasvox's Avatar
QuoteOriginally posted by cats_five Quote
I wonder if the OP has given up yet with this thread?
Possibly, or maybe he has discovered the other 864 threads on this forum which have beaten to death the very same subject and almost verbatim the very same question posed.
Jason
04-01-2011, 04:45 AM   #66
Class A's Avatar
first of all, let's get rid of th ebiggest myth out there. RAW data is NOT data right off the sensor.
If it were, it would be a series of varrying intensity red, green and blue dots.
Your wrong and right. RAW files actually do contain a series of varying intensity red, green and blue dot values. The RAW converter "dcraw" has a switch which allows you to see all the dot values before demosaicing.
That's part of the beauty of RAW files; you can re-develop them years later with better demosaicing algorithms, better noise reduction, etc. Lightroom's 2010 raw converter is much better than its predecessor. If someone wanted to, they could redevelop a RAW file with visibly better results (depending on print size, of course).
You are still right in that the data in a RAW files is not 1:1 what comes from the sensor. Many manufacturers have some built-in, non-optional noise reduction that is applied at higher ISO levels even to the RAW data. There will be hot-pixel mapping, etc.
However, it is the "dot data" before demosaicing.
04-01-2011, 04:53 AM   #67
Class A's Avatar
Great shots, Jay!
04-01-2011, 05:11 AM   #68
A-z
I haven't tried shooting raw yet, I will at some point.
For the moment though, underexposed jpegs seem to be workable to an adequate level. This has been printed 18x12 inches and looks really good!
(although the jpeg upload here sucks )
1st pic is straight from camera
04-01-2011, 06:53 PM   #69
Chex's Avatar
They are all jpeg, browsers can't view RAW files Also converting to a RAW then downsizing them to web size puts them on a pretty level field regardless doesn't it?
04-01-2011, 07:53 PM   #70
SpecialK's Avatar
I think you need to look at the original and the final output for that kind of determination. If you don't know where it started you can't see how far it came. But, I'm probably not a good judge, anyway.
camera, jpeg, pentax help, photography
[K10D RAW+]Exposure difference between RAW and JPEG sterretje Pentax DSLR Discussion 9 04-13-2010 02:06 AM
What do you use most Raw or Jpeg Ivo_Spohr Pentax DSLR Discussion 75 04-02-2010 09:04 PM
JPEG, RAW, JPEG + RAW...huh? Raptorman Troubleshooting and Beginner Help 14 12-22-2009 11:49 AM
RAW or JPEG tkcampbell Pentax DSLR Discussion 24 12-13-2009 04:31 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
All times are GMT -7. The time now is 09:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
